Question about Dryers
Kenmore HE4 mod # 110.95088400 Ser #MS0101029 Intermittent operation, cycling between the three "End Of Cycle Signals", cycling between heat settings. Now dead front control panel, interior light works. What I would like to do is be able to test (via voltage I assume is best) the front panel control boards to verify that I am indeed getting power to it. I've performed test #5 for button and LED's. I get continuity at the posts of all buttons, but no continuity at the socket of the ribbon cable the services these buttons. I can send you "tech sheet" that came with the unit via email or whatever. I've already replaced the Machine Control Electronics board but that didn't fix the problem. I don't want to start replacing pieces as I can't afford that. Plus I like to find a logical reason for the problem. Thank you Gary
Master_Tech
  • 770 Answers
SOURCE: Heat stops after a few minutes, control board already replaced
Thanks for the Chat session I hope I fixed your problem I would like to email you the complete service manual on your model if that is ok it will show you everything and how to break it down please post your email
Thanks Gary
Posted on May 19, 2008
SOURCE: Kenmore Elite HE4 beeps three times when start panel is pressed and wont turn on
FWIW ... the Sears guy came by yesterday. The problem was apparently that the door latch was not operating to the extent that the sensors thought the door was open. He is replacing the latch next week. He adjusted the old one in the mean tiome and it appears to be working fine.
This kind of stunned me, since my wife reported an electric zap and the interior light burned out as the dryer went dead -- so I was sure it would be a fried circuit board -- but, no, a little jiggling of the latch seemed to clear it up....
Posted on Jul 10, 2008
  • 1028 Answers
SOURCE: New Machine Control Electronics needed?
HUH????? just change interface(buttons and board ) have never took time to ck resistance.. front interface just tells machine control what to do
Posted on Sep 03, 2008
tech master
  • 120 Answers
SOURCE: Sears Kenmore Elite Refrigerator model
need model number even though it says kenmore we need to know the model will tell us the maufacturer but start by checking voltage at the outlet to see if you have proper ground
Posted on Oct 17, 2008
  • 41 Answers
SOURCE: Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Posted on May 14, 2009
Kenmore dryer he4 elite dryer not heating model #95862402
using multi-meter need to check the heating element and the thermostats for continuity. you are getting a full 240 volts at the outlet right? if only 120 then u will be able to run the appliance but not the heating cycle.
Sep 25, 2014 | Kenmore Elite HE4 Electric Dryer
If you take the bottom kick panel off, there is a technician sheet that tells you how to run tests. The bad news is the control panel is about 150 and the control board is 240 dollars.
Jan 29, 2014 | Kenmore Elite HE4 Electric Dryer
I have the kenmore elite HE4 dryer and the cycles lights went out and are not coming on how do i fix this
Check and see if child lock is engaged first.
Press the end of cycle signal button for 3 seconds
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
If that don't work I would look for reasons why the dryer duct fuse would blow and correct that by removing air restrictions that would cause overheating.
HE dryer notes and service manual
Apr 12, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer Mod. #110.68932792 Ser. MJ1907445 Dryer in heat cycle starts and runs 10 to 15 minutes then motor stops, after about 2 minutes motor starts back on it's own, operator doesn't have to do...
there is a motor relay in the consol part 3405281,there is also a heat relay too,you can swap em out to see if this is the problem, the one on right side with blue wires is the motor relay let me know how you make out
Nov 19, 2009 | Kenmore Dryers
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Need to initiate cleaning cycle
to enter the cleaning cycle:
Select the RINSE & SPIN button.
Select Low SPIN SPEED'
Select Warm/Cold WATER TEMPERATURE.
Select the 2ND RINSE Option.
Push the END of CYCLE SIGNAL button 4 times within 5 seconds to start cycle
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Gas Dryer HE4-Panel Switch is not Working
repl/ touch panel ,were the front push buttons are the whole assembly ,,
Dec 31, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
