Question about GE JVM1650 1000 Watts Microwave Oven
How do i replace the keypad of GE Profile over the range microwave
I opened the control panel of my GE Profile Microwave. Now how do I disconnect the ribbon cable and take out the key pad. I am getting F3 error and looks like it's related to keypad.
  • GE Master
  • 9,098 Answers
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa:
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. It will help you test the keypad with your meter.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
If you'd rather have us fix it for you, we do that for $39.95 plus parts.
1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip. (A pencil eraser is better and safer).
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
Posted on Apr 20, 2008
GE micro died
The main fuse is the probable cause, magnetron, "heart of the microwave oven" the inverter board, "if 7 years old or less" and the keypad control board can be a factor.
Apr 21, 2012 | GE Profile Spacemaker Over-the-Range...
Microwave keeps running when door open
The problem is caused by a defective door switch, or possibly the keypad control board.
Apr 09, 2012 | GE Profile Spacemaker Over-the-Range...
Keeps running when door is open
This is a door switch problem, or possibly the keypad control board.
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
The keypad of my Profile 2.0 over the counter microwave is frozen in the clock mode
Remove power for 15 minutes and see if the clock resets. However if there is no action on the control panel the fault can be either due to a faulty control pad, a faulty board.
Unless the unit is removed to check there is no other option.
Nov 06, 2011 | GE Profile Spacemaker Over-the-Range...
I have a GE microwave and F3 has just come up on the display screen???
F3 Shorted key panel (touch pad).
1. Will occur if a shorted key panel is detected continuously over 60 seconds.
2. Replace key panel (touch pad).
What you can first try before replacing the keypad is first unplugging the microwave. Then you can get access to the panel by first removing the top grill and then unscrew the top of the control panel. There is a strip that looks like tape which attaches to the control panel which you need to wipe off and then blow dry. may not work the first time but be patient. also clean the bottom of the door and the latches to make sure the connection is clean. After that is should hopefully work without replacing the touch pad.
Let me know how this works out for you.
Apr 26, 2010 | GE Profile Spacemaker Over-the-Range...
HELLO, On my built in over the range ge profile
click on the link above and it will be able to supply you with your manual. It also has contact information so you can call toll free to ask your question.
Dec 06, 2009 | GE JVM1840 Microwave Oven
Panel periodically acting up - says there is a short in the panel
Hello there:
what this is trying to tell you is that your control panel is starting to go out due to a failure in the controle assembly
yes it is feasable to replacethe panel youwill just have to contact the manufacture of the microwave and get a replacement panel/ controle board ok
I hope that this is very helpful for you
Best regards Michael
Nov 21, 2009 | GE Profile Spacemaker Over-the-Range...
GE JVM1650 1000 Watts Microwave Oven Logo
945 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
