Question about Sega Genesis 2 Console
I plugged in my Sega Genesis console to my RF adapter and plugged it into my LCD TV. The picture works great, but I have no audio. I bought the AV cable but it cannot plug into the RF adapter. (the adapter end is female and there is no other way to utilize the AV cable with the console). How do I fix the audio?
  • 20 Answers
SOURCE: no picture for Genesis - RF or console?
The problem is most likely not the console. The first thing you should try is cleaning the contacts on your games. Most of the games have tamper proof fasteners so unless you have the right tools you won't be able to open them. You can take a q-tip with a little alcohol (damp not wet) and clean both sides of the circuit board on the cartridge until the q-tip comes out clean. Let it dry before sticking it into the console. If you do this to a couple of games with no luck try taking an emery board (for fingernails) and gently inserting it into the connector in the console a few times all along the length of it. Make sure to only push it straight in and pull it straight out. If you try pushing it side to side while it is in there you could damage the connector.
Posted on Dec 08, 2007
jyackle5
  • 8197 Answers
SOURCE: I need hook-up instructions for my 16 Bit Sega Genesis system con
Go to this link.
http://imageevent.com/gamescans/gamemagazines/segagenesismanual
Good Luck
Posted on Jan 23, 2009
DarkWolfBomb
  • 80 Answers
SOURCE: how do i set up my sega genesis
There should be regular av cables and wall adapter for it. Mine came with the wrong cords and that might of happened to you. So if you don't know the av cables go in the back of the tv and plug's in the back of the sega. and the wall adapter goes in the wall. If you don't have the cords than get them off line. Type in:
http://www.amazon.com/s/?ie=UTF8&keywords=sega+genesis+cords&tag=googhydr-20&index=aps&hvadid=2858659671&ref=pd_sl_8zrz6m8bxu_b
cut and paste it online and you can get them.
Posted on Jul 18, 2009
  • 69 Answers
SOURCE: Need step by step directions to hook up a 16 bit Sega Genesis
There should be two plugs on the back of the sega. One for the power cord, and one for the audio/video cord. The audio/video cord is a coax cord with a little box in line. Hook your cable or antenna cable into the jack on the box and hook the end of the cable from the sega into your tv. There will be a switch on the sega or on the box somewhere that designates channel three or four, this is what channel your tv will need to be on to use the sega.
Posted on Sep 23, 2009
  • 47 Answers
SOURCE: Cannot hook up my genesis 2 console to my LCD tv
Hi recommend purchasing a new Mega Drive 2 Audio Video Cable found Here.
http://www.gameoz.com.au/store/sega-mega-drive/mega-drive-accessories/sega-mega-drive-2-av-cable-with-stereo-2-metres-long.html
Posted on May 07, 2010
My sega genisis isn't working on my LCD screen
2q== they have videos on Youtube on how to hook Sega genesis version 1 2 and 3 consoles on up to a flat screen tv or any of the newer TV's. I just use a CRT style TV they are much easier to hook up old consoles too. Just buy a CRT tv type then.
Sep 28, 2013 | Sega Genesis 2 Console
My sega genesis has a clear picture but static sound can someone help?
Try an older TV set. I am not joking. It might very well be the case that newer TV sets/high-end TV systems can't handle the signals of the older video game consoles. Because the newr tv;s don't have the signal transfer inside of them to make the old consoles work so you could use the genesis av cables to hook up to a digital tv instead of the rf switch.
gen_av_cable_2_3_tmb.jpg&maxx=130&maxy=120gen_av_cable_v1_tmb.jpg&maxx=130&maxy=120
Mar 17, 2012 | Sega Genesis Console
Sega Genesis 3 has horrible sound quality.
Well it could be that the av cables or the rf switches which ones you are using might be having problems so try a new av cable or rf swtich to see if it makes a difference. If still the aduio is not work there might be an internal issue with the console that should setup a red warning flag like the sound part inside of the console is broken then.
6 STARS IF THIS SOLOUTION IS HELPING.
Feb 18, 2012 | Sega Genesis Console
I have a sega genesis 1 and I bought an av cable because the RF cable is missing. Well I hooked it up and plugged the white and yellow cable in the front of the tv. I put it on channel 3 like the console...
Are you sure it should be on channel 3? Not a TV input mode? Also it could be that the console is shot. Or the cables don't work with the console itself.
Sep 04, 2011 | Sega Genesis Console
My sega is turning on but the picture looks snowy how do I fix it?
Well instead of using an rf switch use the av cables for sega genesis console lukue games I use the av cables instead of the rf switch easier to hook up as well.
Nov 15, 2010 | Sega Genesis Console
I bought a Sega Genesis Model 1 from a thrift store, and everything works great, but it looks like some one has turned the darkness up on my tv when i play games. I tried it with both the genesis RF and an...
Hi, get your hands on a new AV cable you will notice a great difference in picture quality compared to the RF switch. see www.gameoz.com.au as they stock the cable you require. They also can modify the console with a s-video out put which would be one of the best picture quality possable available from one of these retro consoles
Sep 16, 2010 | Sega Genesis Console
Can't find the frequency for the genisis 1 sega megadrive, I have the RF converter but I've tried doing auto search and manual, just cant find it...
Hi some new TV'S may not have the frequency of these old consoles i recommend purchasing a AV cable which is can be found at http://www.gameoz.com.au/store/sega-mega-drive/mega-drive-accessories/sega-mega-drive-1-av-cable.html
No tuning in a channel and better picture Quality
Apr 24, 2010 | Sega Genesis 2 Console
Bad picture with Sega Genesis model 1
Taking your problem in a whole new direction, why don't you try purchasing an 8 or 9-pin (depending on the type of Genesis you have) DIN RCA cable. This will improve picture and sound, and you won't have to worry about malfunctioning RF converters. Your problem sounds like the RF adapters are inadequate.
Sep 16, 2009 | Nintendo Super NES Console
I have a sega genesis. i hae no look how to hook it up. please help me.
well a sega genesis there are 3 different models all either using RF adaptors or AV cables
if RF adaptor please follow this
plug the RF adaptor into the back of your tv the coaxal cable for your tv service ushally runs through this, and plug it into the the back and you can also plug the service into the RF adaptor for the sega genesis. plug the power in and make sure you are on the correct channel (3or4)
If you are using AV cables please advise and I will post the following for that.
Aug 11, 2008 | Video Game Consoles & Games
Sega Genesis 2 Console Logo
97 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Norman Worley
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
