Question about Compaq Presario sr1403wm AMD Sempron 3000+ Computer PC Desktop
Slave hard drive causing boot error with Compaq Presario SR1403WM Desktop PC
  • 70 Answers
Check the jumper setting. jumper create this type of problem.
Posted on Jul 15, 2010
  • herman guerrero Sep 11, 2011
    how do I make the second HD a master, slave , etc...
On the primary hard drive it is connected to the sata1 on mother board. I added another hard drive as a slave. How do I get my system to boot without the boot menu options on
select the primary hard drive as the first boot device, or if you dont have option for this in BIOS, it means that your system boot from the primary drive as default
Apr 22, 2012 | HP Compaq Presario SR2027X (RK554AA#ABA)...
I need to know if the dvd drive for my Compaq Presario SR1403WM Desktop PC runs on a scsi connection system.
The computers compartibilties are ascertainable by powering on to observe the system features once settings are displayed. Also, connect hardwares to the computer to ascertain the condition of display since the manufacturer may least have recognised useer request to several device connection.
Feb 09, 2011 | Compaq Presario sr1403wm AMD Sempron 3000+...
Computer fails to boot. searching for either hard
These pins are referred to as "jumpers". Each manufacturer can have their own jumper settings. Each device should have letters indicating which pins correspond to master, slave, or cable select. The best method to insure operation is to use the cable select (CS) jumper setting. Using this setting, the hardware will be automatically configured.
Mar 11, 2010 | Compaq Presario 5000 PC Desktop
Compaq presario sr1800nx won't turn on
Check the jumper settings on the DVDRW. Depending on IDE location, you need to set the jumpers accordingly. If you have the main system hard drive on the same IDE channel as the DVDRW, set the jumpers on the DVDRW to slave, if that don't work, set them to Cable Select. I'm assuming it's an IDE drive and not SATA.
Dec 30, 2009 | Compaq Presario SR1800NX Desktop PC
I am getting an error message of setup did not
Hmm did you plug in the cables to the HD right or set it to Slave instead of Master drive ( it's on the back of the HD next to where you plug in all the cables, has a little switch and says "Master" or "Slave" switch to Master )?
Nov 18, 2009 | Compaq Presario 5000 PC Desktop
Won't pass startup bios / screen
Make a note of the number of beeps and whether they are long or short. Put the old video card back in the machine. Go online and do a search for "bios beep codes", check what you wrote down and see what the problem was. It was probably a video error. Perhaps you should install the video drivers for your new card before you install it, that way it might avoid the error on startup.
Jan 05, 2009 | Compaq Presario sr1403wm AMD Sempron 3000+...
Non-system disk or disk error
Ththe comuter is presumably fdinding a disk at boot up.
Ensure there are no disk in the drives.
Dec 29, 2007 | Compaq Evo D310v PC Desktop
MOTHERBOARD BEEPING
Beep codes are used by motherboards to indicate what error could cause the system to malfuntion. Try opening this link. It contains all of the beep codes of hp motherboards. There is also a guide here on how to test your computer.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bph07107&product=435558&dlc=en%E2%8C%A9=en
Dec 18, 2007 | Compaq Presario sr1403wm AMD Sempron 3000+...
Computers & Internet Logo
106 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
