Question about Sceptre Komodo X37SV 37 in. LCD Television
The blue power light just binks when it's plugged in, the power button doesn't even have to be pressed. is that the power supply or the logic board? (already ruled out inverter board)
  • 11,361 Answers
  • Sceptre Master
  • 8,457 Answers
Check the power supply board for those dead capacitors.It alway have bulges up on it tops or puff up on it tops.Replaced those dead gases leakages capacitors.Than,it is the power supply board it dead power supply board.No,capacitors bulges up on it tops or puff up on it tops.The logic Tuner board is dead.
Posted on Jul 15, 2010
LG 55LW5600 problem Symptoms: no audio, no video, no backlight.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 12, 2017 | LG Televison & Video
My TV intermittently will not power on properly. Should I replace the logic board or the power supply board?
easy answer I always replace the least expensive part first. If it doesn't fix it at least you have a new part. since the logic board talks to the power board it could be either one.
May 17, 2015 | Hitachi Televison & Video
The TV won't turn on. The little light by the power button doesn't even come on
Blown fuse caused by a shorted power supply. Relacing the power supply board should solve the issue in most cases. You can get a power supply board from www.tvrepairworld.com
Oct 27, 2012 | Polaroid LCD-1700 17 in. Television
TV will not come on even though the light turns blue
check for leak or bad capacitors in the power supply board, then if you can make a voltage checking just to ensure if output voltage in the power supply board are present. the 5v standby 5v switch 12v and 24vdc at the power supply doesn't drop.
Sep 03, 2012 | Televison & Video
Sumsung hps5053 would not turn on
I fixed this model of TV. Symptom was NO POWER. Totally dead. Not even a blue LED up front. Here's what I had to do...
I found a blown thermistor on the power supply board. It's green and located near the 120vac mains input to the board. There is a component number written on the board near it (as with all components) and it begins with "TH" i believe. So it will be something like "TH101". It was very easy to identify that this part had gone bad on my power supply, as i was literally blown apart and debris had been scattered all about the area.
Before finding this faulty component, I had done some preliminary voltage testing from the power supply's outputs. I started with the 5 volt stand by signal feeding into the logic controller board. It was bouncing around from 1v-3v.
After replacing the faulty thermistor, there was a steady 5v signal on the standby circuit. However, the blue power button was still not illuminating. And there was absolutely no voltage going into the power button board (which is fed from the logic controller). So after attempting to replace a few dozen suspect high ESR SMD caps on the logic board (to no avail), I ordered a new one.
And then the TV came to life.
Works great now!
Feel free to ask for advice.
Chris Boise LCD sales@boiselcd.com www.boiselcd.com
Jan 27, 2009 | Samsung HP-S5053 Television
My Soyo DYLT032 has power but no picture or sound
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Dec 28, 2008 | Soyo DYLT032C 32 in. LCD Television
Problems with Soyo DYLT032C 32 in. LCD Television. The TV will not turn on, I have un-plugged it and plugged it back in, in hopes it would re-set the tv. Do you have any suggestions?
Long story short:
Dec 10, 2008 | Soyo DYLT032C 32 in. LCD Television
My philips 42PF 7320A/37 has not been working for the past year. it will work for a few months, then the picture will go black and the light on the tv will blink about 7times. this plasma is only 2yrs. old...
This what to do measure from the logic board which is located under the small signal board and have the AV jacks connected to it. If the voltage is 3.1 or close the problem is with the power supply or a board connected to the power supply. Unplug the set. Disconnect the Y main board first that will be on the left side of the set facing the back. Plug the set back in if the led is solid replace the Y main and the Y upper lower. If still blinking plug the Y main back in and unplug the X main which is on the right side facing the back. If the led is green replace the X main. If the led is still blinking replace the power supply.
But if the volts are 0 the problem is the SSB or the logic board. In that case take the (SSB) small signal board out the set and place 1 jumper on J8003 and another jumper J8004 of the left side of the power supply. Then place 1 jumper on CN2072 of the lower left part of the logic board. Plug the set back in if the set displays a white, blue et c screen replace the SSB. If not and on the logic board you don't have 1 solid blue led and 1 blinking led data is not flowing and change the logic board.
Jan 04, 2018 | Philips Televison & Video
Monitor won't turn on
The inverter power supply logic board has probably goe out. You can get it here or have it fixed.
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
Mar 30, 2008 | Dell E176FP 17" LCD Monitor
Sceptre Komodo X37SV 37 in. LCD Television Logo
661 people viewed this question
Top Sceptre Televison & Video Experts
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
