I replaced the LCD monitor on my asus eeePC900 XP and everything is great, but I can't adjust the brightness. If I press Fn and F4 which s to lower the brightness, I get an ''LCD only'' message. It is on max and I can't lower it.
    Sniper:
  • 51 Answers
FN+F3 should increase the brightness and FN+F4 should decrease the brightness (or the other way around). Failure in that, you should try doing this through your operating system or through the BIOS
Posted on Jul 15, 2010
How do i turn off num lock?
Press FN+Shift+Num Lk key at the same time
Here are FN + F key combi for your reference.
Press Fn + F9 keys for Touchpad Lock (on/off).
Function Keys:
Fn+F1 Suspend switch
Fn+F2 WLAN switch
Fn+F2 Bluetooth switch
Fn+F3 Access to the E-mail
Fn+F4 Access to the Internet
Fn+F5 Brightness down
Fn+F6 Brightness up
Fn+F7 LCD on/off
Fn+F8 LCD/CRT switch display
Fn+F9 TouchPad Lock
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Fn+Space Power 4Gear eXtreme
Fn+C Splendid
Fn+T Power4Phone
Fn+V Camera capture
Fn+A Light Sensor
May 18, 2014 | ASUS VivoBook S400CA
How do I use the function keys on my Eee PC to view picture through my video projector?
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 ASUS and Dell = Fn + F8
Apr 13, 2013 | ASUS Eee Computers & Internet
How to increase brightness without fn+f6 keys because for now the f6 key is not working
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Oct 08, 2012 | ASUS EeePC1000 1000H 1000HA 1000HC 1000HD...
Hp laptop no longer connects to external display via fn + f4
The Fn+F4 button toggles between the LCD and external monitor.
From LCD only or both LCD and external monitor or external monitor.
only. Press the Fn+F4 keys again to toggle the various screen selections.
Sep 16, 2012 | Computers & Internet
When I connect my ASUS monitor to my Dell laptop the ASUS monitor displays nothing instead it says "No Signal"
Hi
You do not say if your laptop screen is working or not or why you want to use an external monitor.
Assuming the laptop has no fault and boots properly, to send the laptop image to an external monitor, once you have booted into Windows, press and hold the Fn (function) key bottom left of your keyboard, near the Windows Logo key, then simultaneouly press the Function key (above the numbers) with the image of 2 monitors, 1 dark, 1 bright (often the F4, F5 or F6 key).
If the laptop's screen is faulty and the above procedure does not work, there may be damage to the graphics card which will probably require specialist repair.
I hope this helps.
Aug 27, 2011 | ASUS MW221U LCD Monitor
The display is black
If you can still hear everything else working try adjusting the brightness, there should be keys to do this on the keyboard, if it has no effect i suspect your lcd back light has gone.
Jan 20, 2010 | Fujitsu Siemens AMILO Xi 1546 Notebook
Cant turn the brightness down on my asus netbook
You should be able to use the "FN" key and "F5" key, press and hold the "Fn" key then while holding that key, press the "F5" key to decrease the brightness. Use the same(Fn) key and "F6" to increase the brightness.
Jan 02, 2010 | ASUS Eee 4G Notebook
Presario 700 LCD laptop problem brightness problem
there is a brighness key on your kb
press the fn key on lower left and turn up your bright ness
fn = function press and hold while you press bright ness up
Jul 31, 2009 | Compaq TFT5010R 15" LCD Monitor
Fn combination keys for external monitor
Key Combination Functionality
Fn+F3 Reduce speaker volume
Fn+F4 Increase speaker volume
Fn+F5 Switches display: LCD, CRT, and LCD/CRT simultaneous
Fn+F6 Increase LCD brightness
Fn+F7 Decrease LCD brightness
Fn+F10 Toggles battery warning off and on
Fn+F11 Switches the LCD panel off and on
Fn+F12 Places the computer into Hibernate mode
May 22, 2009 | Compaq Keyboard
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
90 people viewed this question
Alun Cox
David Payne
David Payne
