Question about LG LRE30453ST (Electric) Stainless Steel Range
LG LRE30453 (Electric) Range Problem is front left burner is shut off but the burner remains hot ... Range won't stop beeping. ...
I have a lg electric dual convection range (Model # lre30757st) and the front left burner turns on and off on its own. (It will not remain off.)
Posted on Jan 27, 2011
Left front range top burner temerture control issues
Good Morning Friend,
I understand that you are having trouble with the left front burner on your Frigidaire range, model# FEF355. I see that the burner heats up to a glowing red hot temperature, no matter what you set the dial to. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes.
When power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button, then within 5 seconds press and hold the up or down arrows until the correct time of day appears.
Once you have set the time, turn on the left front burner, on the lowest setting. If the burner is still glowing red hot, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your range and determine what is causing the burner to glow red hot on all settings. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
LG Range LRE30453ST Error Code F-7 oven heating takes long time.
Loo I am going to tell ALL LG rang owners on thing, they worked on my top two stage burner, after that the oven either would not heat up or take for ever to come to temp. Now the oven superheats, set it to 320 degs F and it goes to over 600 deg's F. I called LG and got NO HELP AT ALL, so I went to the Consumer Products Safety Commission and filled a complaint about the range! I suggest you do the same!
Sep 13, 2011 | LG LRE30453 (Electric) Range
Large left side, front burner, does not shut off when you turn the control knob to, OFF. It gets very very hot and remains that way for a long period of time. I can keep turning the , OFF, knob, but...
That means the switch is shorted(the contacts welded their self together) the only fix for that is to replace switch. AS A SAFETY PRECAUTION UNTIL THE SWITCH CAN BE REPLACED TURN OFF CURCUIT BREAKER TO STOVE
Gene
Aug 01, 2011 | Kenmore 95313 Stainless Steel Electric...
Range top front burner will not shut off, stays on high, back burner up button does not work and timer does not work. Even though it was fixed in Feb of this year LG will not fix it again
I have the same problem with the LG LSB5682SW Electric Range - Font Left Burner will not go off / stays on high. This is very dangerous. LG customer service is horrendous. I think it is time for a recall before someone's house burns down!
Jun 30, 2010 | LG LRE30755 Electric Kitchen Range
LG lre30451S burner will not shut off. It is stuck on high and the only way to get it to go off is to flip the breaker. When I flip the breaker back on the burner goes back to high. Thanks
I had the same problem with my LG front left burnr. Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Relay is the problem. I had the same problem with my front left burner stuck on high.
After replacing relay everything works fine.
Mar 02, 2010 | LG LRE30451 Electric Kitchen Range
Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Problem with electric range
Most likely the switch has welded closed
Sep 28, 2007 | Kitchen Ranges
LG LRE30453ST (Electric) Stainless Steel Range Logo
487 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
