Question about GE Ovens
Gas oven won't light on bake setting
I have a ge gas oven model jgbp29eej1bb and the oven won't light on the bake setting but the upper element will on the broil setting
  • 375 Answers
If the bake ignitor comes on (starts glowing) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. Faulty gas valve is uncommon, but still a small possibility. Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
PS For your model number the original part number was WB13K4 or WB13K0004, which is a round ignitor, though on the breakdown a rectangular one is shown, so check carefully.
Posted on Jul 15, 2010
How do I replace the bottom element of my GE oven?
Hundreds of GE ovens, so can't give procedure, but problem is not necessarily the element - could be switch, connection to element, etc. Google GE (model #) lower element not heating.
May 27, 2016 | GE Ovens
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 | Ovens
Whirlpool oven WGP30801
Your model suggest a gas unit on gas units only bottom burner operates in bake on electric bottom elements heats broil cycles.
Feb 12, 2014 | Ovens
Oven doesn't go on.
Hi.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
If the part that is not heating is only one element, then you may need to replace the element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
In this case, selecting only baking or only broiling (depending on what element is faulty), the oven will work normally.
If the oven is a gas oven, then you have no element. In that case if the oven burners are working, replace the temperature sensor.
If replacing the temperature sensor does not help, then replace the oven electronic control.
Mar 04, 2010 | GE Ovens
Oven takes 20 minutes to fully heat on bake - Kenmore oven plt095-2
if its a gas model most of the time you will have a weak oven ignitor. if an electric,check to see if the bake element gets hot ,some ovens will bake with upper and lower elements so if only the upper works it will take much longer to pre-heat.good luck!
Jan 16, 2010 | Kenmore Ovens
GE oven will bake but not broil
I trhink more than likely you have a faulty element, you need to test wether you have power to the element with a voltage tester or meter
Nov 22, 2008 | Ovens
GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
Benjamin
Nov 19, 2008 | GE JGRP17 Gas Single Oven
F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Nov 18, 2006 | GE JGRP17 Gas Single Oven
Ovens Logo
264 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
