Question about Acer Aspire 3680 Laptop
Laptop powers up but will not boot. Replaced hard drive and still have the same problem.
  • 942 Answers
Since you already replaced the hard drive and the problem still persist, there are only two things that you need to consider, either replace the power supply if your laptop has no lights when you turn on the pc or replace the motherboard since the circuitry of your laptop is off.One last troubleshooting is to turn off the laptop, remove the cables and battery and press n hold the power button for 8 secs. Then reinsert the cables and battery on the laptop and turn it on. If symptom persists, call ACER and have your computer repaired immediately..
Posted on Jul 15, 2010
Disk drive not opening but getting power
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Apr 16, 2013 | Computers & Internet
My hp compaq nc6220 is not able to boot to the OS. What could be done to resolve it?
Dec 10, 2012 | HP Compaq nc6220 Notebook
L-555/ no hard drive indicters or wireless or memory lamp but powers up
Nov 29, 2012 | Computers & Internet
When i power up my laptop , all i get is PXE-E53 No Boot Filename Recieved PXE-M0F : Exiting PXE-ROM
Aug 25, 2012 | Toshiba Satellite Computers & Internet
ACER 5600 NOT BOOT AND CD DRIVE WILL NOT OPEN
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 08, 2012 | Sony VAIO PCG-K25 Notebook
Reseat hard drive
The hard drive can be removed and reconnected (reseating) by removing the screw/s on the bottom of the laptop. The hard drive compartment will have disk symbol. Open the laptop lid slightly before you slide out the hard drive. Insert the hard drive back into the laptop so it makes proper connection.replace the screw/s.
Boot up the laptop, if it does not boot up then power off and power up and press F1 to go into IBM BIOS setup - check to see if the hard disk is detected. If not then the hard disk is faulty and needs to be replaced then Windows needs to be installed on the new hard disk to get the laptop operating again.
May 30, 2012 | IBM Thinkpad T43/p Notebook
I dont have boot dissk for my asus f5r laptop what can i do it says reboot and select proper boot device or insert boot media in selected boot device and press a key_
Your ASUS cannot find the hard drive to boot up.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 08, 2012 | ASUS F5RL-B1 (90NM6A233474421L750Y) PC...
Toshiba 350b satallite laptop won,t boot up have power but no hard drive activity
Mar 04, 2012 | Toshiba Satellite A135-S2386 Notebook
PXE-E61 : MEDIA TEST FAILURE , CHECK CABLE
Normally, your laptop should be configured to boot up from the hard drive before trying the network boot up. When the hard drive fails or is no longer available, or the boot up sequence in BIOS Setup has been changed so that the network boot is set before the hard drive, the symptom you describe fails.
I would recommend that you do the following:
1. Check BIOS Setup & make sure the boot sequence is set in the correct order (Hard Drive 0 should be before Network Boot).
2. Make sure that the hard drive is seated properly in its slot & that all connections are tight.
3. Make sure that the hard drive powers up when you turn on the laptop.
If none of this helps, then your hard drive has failed & might need to be replaced.
Mar 09, 2011 | Compaq Presario 700 470024-192 Notebook
Wont boot up, have replaced charger but still wont boot up
laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre to help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Dec 31, 2010 | Computers & Internet
Acer Aspire 3680 Laptop Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
