Question about Intuit Quickbooks Premier Manufacturing & Wholesale Edition 2008 Full Version for PC (403705)
We are using QuickBooks Premier 2008 for Manufacturing. We seem to have glitch in the inventory module where the product has been receieved and shows up with the correct amount (4,950 pieces) in the "Items & Assemblies" list, yet the parts do not show in the Pending Builds file. As a result we are accumulating many Pending Builds even though w ehave many thousands more than we need in stock. We do update the date when trying to build Pending Builds, but to no avail. The system has allowed us to receieve the parts and pay the vendor, but the parts still do not show up when trying to assemble Pending Builds.
    President:
  • 567 Answers
Hi there, the software seem to have a problem which is a manufacturer defect and cannot be fix, you should try a different version of Quickbooks.
Posted on Jul 15, 2010
  • steveparker Jul 15, 2010
    We seem to have solved this intermittent problem by re-entering the "missing" received parts under "Receive Inventory Without Bill". The system immediately doubled the amount of inventory and then reverted immediately back to the proper inventory count. It is as if the system recognizes it's past error. If it had not reverted we would have manually adjusted the count to the correct amount.
  • Hilton Bristol Jul 15, 2010
    Thats great news i am please to know the problem is solved.
    Thanks for letting me know everything is okay now.
QUICKBOOKS 2007 TRIAL
Premier 2007 (General, Contractor, Manufacturing & Wholesale, Nonprofit, Professional Services, Retail)
Pro 2007
Enterprise Solutions v7.0
Simple Start 2007
Mac 2007
Need help installing after you download?
http://support.quickbooks.intuit.com/support/Static/INF12417.html
for more help call 1-855-383-7236 or visitQuickBooks Tech Support
May 11, 2014 | Intuit QuickBooks Pro 2007 Full Version...
Tip
Quickbooks Download Websites
IF you are using Intuit Quickbooks, Here's the download Websites:
Quickbooks Pro 2008 : Download
Quickbooks Premier 2008 : Download
Quickbooks Pro 2009 : Download
Quickbooks Premier 2009 : Download
Quickbooks Pro 2010 : Download
Quickbooks Premier 2010 : Download
Quickbooks Pro 2011 : Download
Quickbooks Premier 2011 : Download
Please make sure you know your License Numbers
Please rate if this helps..
Thanks!
on Mar 16, 2011 | Intuit QuickBooks: Pro 2005 for PC
How to load data base into quickbooks pro so it is a click away
From there, it's easy to invoice clients in a few clicks so you won't miss any ... Based on 2008 survey of QuickBooks Pro & Premier customers who expressed an opinion ... Easily transfer your existing data file into QuickBooks 2010. ... Quicken 98 through current version can be transferred to QuickBooks 2009. ...
quickbooks.intuit.com/product/.../small-business-management-software.jsp
Jul 10, 2010 | Intuit QuickBooks Premier 2009 Full...
I need to practice on Quickbooks Premier 2008 for students ( or something like that) Where can I found this program whit backup files?
The best program for learning QuickBooks is the free Simple Start Version. You can download it for free at quickbooks.com.
www.cpahispano.com
Mar 27, 2010 | Intuit QuickBooks Premier 2008 (3-User...
Item number setup
QuickBooks is not really designed to track lot/serial numbers, but here is something that may work:
1) From the "Item List"
2) Add (or Edit) an "Inventory Part"
3) Click on the "Custom Fields" button
4) Then, Click on the "Define Field" option
4) Then, place a check-mark in the "Label" box and then type "MFG Lot #" in the "Label" field
a) Most reports will allow you to "show" this new custom field
b) Warning: Custom Fields (in QB) are merely a "text" box, so don't expect to establish "drop-downs" or filter by a specific choice, since filtering requires "exact" text match. (for example, if someone types the lot # as: "1001-9008" (with hyphen) and you search for "10019008" (without hyphen) QuickBooks will not recognize as a match, when filtering/searching the reports.
Feb 04, 2010 | Intuit QuickBooks Premier 2008 (3-User...
Convert QB POS to QB Premier Accountant
a) If you previously syncronized POS 2008 with the financial product, then no, you cannot syncronize the data again, unless you tag each transaction (for the whole years) as "unsent".
b) If you have never syncronized POS 2008 with any QuickBooks Financial product, then yes, you can syncronize/download the data into QB 2009 Accountant Edition.
Before you do either: Make sure you do not already have 2008 data in your file.
Jan 14, 2010 | Intuit QuickBooks Premier Accountant...
Quickbooks (2008 Premier) invoices sent to print
Hello
Thank you for using
FixYa for your problem
Can you try a different PDF creater
http://en.pdfforge.org/download
this I find to be very good and free
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Quickbooks quits when I try to print a previous reconciliation
You need to run the file in a Premier Version. Premier Version is the only version that access the previous reconciliation.
www.cpahispano.com
Jan 21, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Quckbooks 2003 upgrade to 2008
you need to import your company file into Quickbooks 2006 first, then from there into 2008.
Marcus
Nov 02, 2007 | Intuit QuickBooks Premier: Accountant...
Intuit Quickbooks Premier Manufacturing & Wholesale Edition 2008 Full Version for PC (403705) Logo
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
