Question about Garmin nuvi 1350 Car GPS Receiver
My Nuvi 1350 will not connect to PC--PC gives the audible tone--Picture of the unit to PC on Display, then then the remove harware audible sounds--it keeps doing this every ten seconds or so--can't register the thing.
fathitkf
  • 1871 Answers
SOURCE: nuvi 1350 randomly shuts down
Hello :
Try to replace the battery . Because I think that the battery is almost at the end of it's life .
If that didn't work , then I recommend you to reset your NUVI .
Here is the resetting method :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Posted on Apr 15, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a Garmin Nuvi
Check it out here.
http://www8.garmin.com/support/outofwarranty.html
Posted on Sep 11, 2010
  • 589 Answers
SOURCE: need to register my garmin
with unit off
connect your gps using the USB cable to your computer, it will then detect the unit
go to www.MyGarmin.com
the site will detect your unit and let you Register the unit there, unlock maps and update Firmware
FYI...... when you set up the GPS at the location your at, it will now be your SECURITY LOCATION so remember the spot just in case you lose your Pin Number to unlock your unit
If you lose your Pin you will have to travel within 50 meters of SECURITY LOCATION to unlock the maps if you set up the security lock feature...
Read the Help section in your unit to know it better lots of good info there,
Posted on Oct 30, 2010
  • 589 Answers
SOURCE: I have a nuvi 1350, how to register for later
with the unit Off
connect the gps to computer using the usb cable...( same usb cable most cameras use to hook to computers)
once connected your computer will detect new hardware (usb) minimise box
next
go to www.MyGarmin.com it to will detect your model number and let your register your gps
you will be asked to download WebUpDater utility to transfer files to your gps
Posted on Nov 20, 2010
  • 1514 Answers
SOURCE: how do I register my new nuvi 1350 and get map
Details on registering and updating your garmin nuvi satnav are at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Posted on Dec 06, 2010
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1350 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1350 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Webupdate
Garmin Nuvi 1350 Favorites Backup
on May 15, 2010 | GPS
Does not start
itll need the files putting back on it.it has crashed and lost something off it..
Oct 23, 2017 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 1350 screen black cracks
it sounds like the unit has been dropped and has cracked on the inside of the screen. we see this a lot with mobile phones. you may need to have the internal screen replaced.
Jul 12, 2010 | Garmin nuvi 1350 Car GPS Receiver
Tip
Download Garmin Nuvi 1350 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Tip
Download Garmin Nuvi 1350 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 15, 2010 | Garmin nuvi 1350 Car GPS Receiver
Tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
Garmin nuvi 1350 Car GPS Receiver Logo
853 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
