Question about Refrigerators
Need instructions on how to replace door gasket of dometic 2310 rv refriterator.
  • carol_h_7970 Jul 15, 2010
    This gasket has no screws; this is an RV refrigerator, 3 way: 110, 12 volt and propane. So, the above does not work. Thanks anyway.
  • 1,889 Answers
Loosen all the screws located in the middle of the old door gasket, remove the old gasket. starting at the top of the door; wedge the new door top gasket corner into one of the gasket frame corners at the door top and, screw it down to secure; because the gasket will not be wide enough; use a hairdryer to gently stretch it to the other top corner and, secure that corner then : using the hairdryer continue to stretch the gasket downward and, fit the rest of the door gasket into both of the remaining bottom corners then: slip the rest of the gasket under the gasket frame and, tighten all the gasket frame brackets.
Posted on Jul 15, 2010
Dometic fridge NDR1292 in RV has started to make a hissing noise at least once a day for about 5 seconds. Also, cooling fins are icing up very quickly, every few days. Does something need replacing?
NDR 1292 amish style cooling coil replacement - YouTube
? 8:13
www.youtube.com/watch?v=Ru6lFABsqnk
Oct 13, 2012 - Uploaded by taintedcrimsonwings
Step by Step instructions for replacing a Dometic NDR1292cooling unit. ... RV Refrigerator Cooling Unit Replacement Part #2 Installing The ...
Sep 27, 2015 | Dometic NDR 1292 Refrigerator
Need a door gasket for a dometic model 1402
Although you might be able to match it up with other manufacturer door gaskets and it work. Dometic door gaskets are available from most RV places or direct from Dometic.
Feb 04, 2012 | Dometic Refrigerators
13.5 Dometic rooftop rv ac design has changed since I purchased 2006 Monaco Camelot rv. The collection cups leading to the drain line do not fit well on the roof seal and a good seal is hard to achieve. If...
I've not run into the problem your having yet, so I will apologize up front for asking you to furnish more information. These drain cups that I assume are little round pieces attached to the base of the unit where it meets the roof, were not common on dometic, but were common on Coleman AC units. Those are the outlets for condensation to the roof anyway, are they not?
Also, as far as gasket goes, no I wouldn't recommend using 2. We were always advised by manufacturer to compress gasket to half the original thickness when installing either Dometic, or Coleman (RV Products). Coleman at one time, had tabs under gasket that when gasket was compressed, and they touched the roof surface inside, that was far enough, which was approximately half the original thickness. Believe it or not, over-tightening is more likely to cause a leak. Stick with half original thickness, or close to it.
Jun 26, 2010 | Dometic Rooftop RV Air Conditioner
Dometic RV refrig model NDR1292 seal on right door
Here's a link to number to call for info on replacement parts available.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Spare-Parts/
May 20, 2010 | Dometic NDR 1292 Refrigerator
RM2652 Refrigerator: I have a DM2652 model Dometic RV refer. It is leak...
Dometic Voluntarily Expands Refrigerator Recall
Dometic recently expanded its recall on a population of two-door refrigerators. The original recall included some two-door refrigerators manufactured between April 1997 and May 2003. The new recall focuses on models manufactured between June 2003 and September 2006.
To see if your unit is on the recall list & what to do, try the link below.
If your unit is on the list, DO NOT run your refrigerator on propane until the kit is installed
http://www2.dometicusa.com/recall.php
May 18, 2010 | Dometic RM2652 Refrigerator
How do I remove the door on a dometic 1292 RV
peel back the rubbers and you will see screws undo then and the plastic door ligning will come of with the seal taske of old put on new and replace in reverse
May 15, 2010 | Dometic NDR 1292 Refrigerator
How to change a rv air conditioner gasket
you need to remove the unit, replace the gasket and reinstall the unit.  It easier if you have a friend to help.  can't you simply use a good clear sealer...after all it's on the roof and who's going to see it?
Apr 01, 2009 | Dometic Rooftop RV Air Conditioner
Roof gasket on rv a/c
Try not to compress gasket past 1/2 it's original thickness. Most of the factory ones have tabs that stick down, and supposedly when they touch the roof, it's far enough, which is about same as 1/2. I use my cordless with the torque setting on it, at about 2-3 until I see how far that draws down, then increase/decrease as needed from there.Once i feel it's 1/2 way, I torque all at same setting on drill to make sure all equal.
Aug 15, 2008 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
817 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
