Question about KitchenAid KGSS907SSS Gas Kitchen Range
Kitchen aid kgss907sss00 displaying close door when door is closed. oven will not turn on
Powerman
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
SOURCE: Kitchen Aid Double Convection Oven stopped during Self Cleaning
I had the same problem--despite having had my top of the line KitchenAid oven for many years, it is dead after using the self clean feature for the first time ever. I just got off the phone with KitchenAid customer service. They said they can't help me at all because of the age of my oven. Apparently, they DON'T CARE that there is a well documented flaw with the self cleaning burning up the thermal fuse. If your oven is under warranty, they will help you; if not, you are on your own. This really stinks. I was about to buy a new dishwasher and refridge, but you better believe I will look for another brand.
Posted on Feb 11, 2008
aborcass
  • 2651 Answers
SOURCE: Service Manual
when you took down the control panel and gained acess to the upper cavity , there wasnt a service manual just to the left inside a red plastic bag???, if not there is another fuse loacted just behind the micro front looks to be atop the capacitor area
Posted on Mar 09, 2008
  • 4 Answers
SOURCE: oven door locked
Please check my earlier post on this problem.
I forgot to add that the only way the Tech is able to get the oven door unlocked after it shuts down in the Self-Clean (Self-Destruct?) mode is to take a pair of pliers and short across the bad Thermal Protection swtich before replacing it.
Posted on Apr 28, 2008
  • 338 Answers
SOURCE: KITCHEN AID KCMS145JSS 0 THE
bad control panel.. all power is routed through the control panel.. if your having a problem like that i would replace the control..
Posted on Jan 17, 2009
My ge double oven326b1230p001 the top door is not closing properly and the light keep on,please advise how to close top door
Oven Range Door DIY Repair - YouTube
? 2:50
www.youtube.com/watch?v=6YFTYWsiO1M
Jan 22, 2011 - Uploaded by ApplianceAdvice Watch Queue. TV Queue. __count__/__total__. Find out why.Close ... This video explains how to remove an oven door on many higher end ovens, such as GE, Kitchen Aid, Kenmore, Whilrpool, Dacor, ... Top comments ... fell off and the screws fell down into the oven door and I did not know how to fix it.
Aug 08, 2015 | GE Ovens
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
I cannot turn top oven off from bake. How do I make it work?
have the same problem with kitchen aid stove. Set the cook duration for one minute - then open and closed door. Oven turned off.
Jul 31, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Aid Double Convection Oven blows circuit breaker
the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Feb 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
Self clean inoperative
Dear Superglide, An error code "F5 E1" means "door latch not operating". In such situation I would recomend to replace the oven lock assy (part # 9782611 ) which is located on the back panel.If you are going to do it yourself - DO NOT forget to unplug the power cord first. About service manual - try to call Kitchen Aid directly.
Dec 13, 2006 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KGSS907SSS Gas Kitchen Range Logo
117 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
