Question about Toshiba Computers & Internet
Toshiba satellite becomes unresponsive after bios
I have a toshiba satellite A215-S582. I tried to update the BIOS but it suddenly shut down. Now, it's unresponsive. The screen went blank but the hard drive and fan are working. Is there any way I could fix this at home?
  • Toshiba Master
  • 4,806 Answers
First of all try this. Turn the laptop off and remove the battery. hold down the power button for 30 seconds. Plug just the AC mains power jack in and turn the laptop on.
If it boots all is well, turn the machine off, put in the battery.
Just out of interest can you remember who manufactured the BIOS? was it Phoenix or AMI?
Good luck.
Posted on Jul 15, 2010
  • Lee Hodgson
    Lee Hodgson Jul 15, 2010
    Sorry, don't forget to remove AC power too.
When I try to update Bios on Toshiba Satellite A215-S7462 The computer 'locks up' (becomes completely unresponsive), and the computer's display goes blank (turns off).
Updating the BIOS usually brings up some problems. It burns the motherboard. I suggest that you contact Toshiba regarding this for warranty support.
Dec 11, 2012 | Toshiba Satellite A215-S4747 Notebook
Upgrading BIOS! If it isn't broken don't fix it. Upgrading is a scapegoat fix, and many manufactures have a disclaimer. "You are on you own", and the likes for a reason. Most solutions are found elsewhere. However, if you truly need to update read this to help you with the upgrade. You don't want to end up with a brick. http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
Dec 10, 2012 | Computers & Internet
How to stop constant beeping on bootup after BIOS update and Windows 7 installation?
I know when I flash my bios a lot of things go through my mind until it is over because the last thing i want to see is the computer shutdown. To answer your question it is possible the update you received may have had errors in the files causing the computer to go on a beeping rampage.The only thing I can suggest is contact Toshiba's customer and technical support system to try and get answers.
Mar 12, 2012 | Toshiba Satellite Computers & Internet
Nothibg I do will take me to the boot options screen, It just stays on the opening Toshiba page.
For entering the Toshiba BIOS....
while the system is powering on
1. try pressing Esc and if nothing happens
shut-down and then power-on again
2. try pressing F1 during this power-on
Hopefully either 1 or 2 gets you into the BIOS
Feb 11, 2011 | Toshiba Satellite A215-S4807 Notebook
Updated my BIOS on my Toshiba Satellite a215-s4747 Laptop, now has a BIOS password I can't work around to boot the OS.
You'll need to Reset your BIOS password. To do this, go to another PC, and visit youtube to find a guide, or ring toshiba support and have them talk you through it.
Sep 07, 2010 | Toshiba Satellite A215-S4747 Notebook
I have a Toshiba Satellite A215-S7437 and suddenly appear a password at the begin startup. What Can I Do?
that is a bios password it is a common problem when bios software isnever updated. it is covered under an exception code i believe. email me your model part number and i will tell you the rest of the process monday. or if you want to do it yourself the pin is located under the ram, it looks like two interlocking E's take a flathead and press in between the two
Oct 31, 2009 | Toshiba Satellite A215-S4747 Notebook
I have an Toshiba A215 and cant remember the admin password how can I unlock the system to change my password. I have a toshiba satellite a215-7417 and need to reset bios. I heard something about shorting...
Do not attempt to short out the jumpers on your own. As simple as it is, you can also kill the board. Also, the RTC battery will not effect the BIOS password. Take it in to the nearest Toshiba ASP center and they will reset the BIOS password as well as update it to the latest BIOS revision to avoid it from happening again UNDER WARRANTY. You do not have to pay for this repair.
Mar 16, 2009 | Toshiba Satellite A215-S5822 Laptop
Toshiba satilite a215 s7422 bios password how to cleare
You'll need a special tool that only Toshiba has. I believe you can get yours cleared for FREE if you tell them that all of a sudden out of nowhere you have a bios password. Stick to that story because they've already admitted to the problem with many of their laptops. You'll have to find an authorized Toshiba repair center to take care of it for you. Otherwise I believe they charge around $100 to clear it.
Don't bother to try the cmos battery trick, it doesn't work on your model. The password is stored on an onboard chip.
Feb 21, 2009 | Toshiba Satellite A215-S7422 Notebook
My Toshiba A215-S4747 Crashes every time I move it.
This sounds like the Toshiba Blacvk Screen of Death issue with early A215 models. Re-boot and hold down the F2 key to bring up the BIOS screen. If your BIOS version is less than 1.9, you must update the BIOS.Go to the Toshiba support site and search by model. If your BIOS is ver. 1.9 or later, then go to the power opetion settings and set BOTH the minimum and Maximum power to 100% for BOTH battery and AC. That will fix this about 90% of the time.
Dec 16, 2008 | Toshiba Satellite A215-S4747 Notebook
SYSTEM REBOOTS AFTER SHUTTING DOWN
It seems that when you formatted, you took your Bios settings with it. The latest bios can be obtained from toshibas website....Below is a direct link to the bios.
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1976812xml&sliceId=&dialogID=51709196&stateId=0%200%2051707515
Sep 24, 2008 | Toshiba Satellite A215-S7422 Notebook
Computers & Internet Logo
121 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
