Question about Canon PowerShot A75 Digital Camera
How too ste flash so no dark background - Canon PowerShot A75 Digital Camera
    Problem Solver:
  • 17 Answers
Set the camera to flash mode
Posted on Jul 15, 2010
Why when taking a picture is the background of the picture flashing
If the image you see in the camera display flashes then it's an over/under exposure warning feature that's turned on in your camera. It's there to tell you when an area of your picture is either too dark or too bright. You can usually find a setting in the camera's menu that allows you to turn it off. Look for "Exposure Warning" in your menus or something similar.
Oct 14, 2014 | Cameras
My Kodak EasyShare CX7430 Digital Camera's flash is working, but the picture's background is dark. So, there is no difference even if the we use flash or not. Please help me to solve this issue. Thanks In...
I assume there's a subject in the foreground you want illuminated with the flash?
The light output from the flash falls off with the square of the distance. An object twice as far from the camera only receives a quarter as much light. If you want your foreground subject illuminated then the background won't get much light. In order to get both the foreground and background illuminated the same, turn off the flash. This will probably require you to put the camera on a tripod or other stable support.
You might also want to consider using the Night mode. This mode uses a slow shutter speed to allow the background to illuminate, then fires the flash to illuminate the subject. See http://resources.kodak.com/support/shtml/en/manuals/urg00206/urg00206c2s3.shtml
Aug 24, 2013 | Kodak EasyShare CX7430 Digital Camera
I have a Nikon d200 and need to take sports photos in a basketball court The sport is very fast moving. What should I set the camera to. Lately the photos are dark and or blurry
You want the fastest shutter speed you can get and the largest aperture possible.
If you're close enough and it's allowed, use the flash. The flash will freeze the action. However, it's likely to give you a dark background instead of a blurry background.
If not, use the Aperture Priority mode. Open the lens to its maximum aperture (smallest f/number). This will give you the fastest shutter speed for the existing lighting conditions. The fast shutter speed will freeze the action and the large aperture will blur the background, though the amount of freezing may be limited if the lighting is relatively dark, as in a high school gym.
Be aware that if you're shooting indoors you're going up against the laws of physics. The human eye can adapt much better than any camera. A high school gym will appear light enough once you've been inside for a few minutes, but it is much, much darker than a bright day outdoors.
Apr 28, 2012 | Nikon D200 Digital Camera with 18-200mm...
I use d80 and flash sb 600 on a bracket and when i take a photo when th lights are dim if the subject is close thier lit up but the rest of photo is dark why?
It's the Inverse Square Law. Light drops off as the square of the distance. If an object is twice as far from the light source it only receives a quarter as much light. So, if the subject is lit properly then the background will be dark.
This is a law of physics. However, there are several things you can do about this. One is to move the light source. Another is to have more than one. The D80 can control other flashes, so you can use the D80's pop-up flash to light the subject and the SB-600 (or more than one of them) to light the background. Another possibility is to bounce the flash off a white ceiling or wall to soften and diffuse the light. Another is to use slow-sync, leaving the shutter open longer to let the background illuminate. You can read more about this in the manual.
Jul 14, 2010 | Nikon Speedlight SB-600 TTL Flash
Dark Background on the paper
replace the drum unit (toner) your drum is weak causing dark background
Nov 21, 2009 | HP LaserJet 4 plus Printer
When I use the flash the front of the picture is very bright and the background is very dark.
That's normal. It's called the inverse-square law. When using a camera-mounted flash, you have to decide what you want to expose for.
Sep 26, 2009 | Nikon COOLPIX P80 Digital Camera
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Flash
if your setting is set on auto focus then it will automatically sense any presence of backdrop light, if the sensing device cannot see or seen a dark background then it will work automatically, not all condition will be met under some condition,
try focusing on a brighter image or with good light exposure, this might prevent the flash from flashing but will and should work in dark areas.
see your seting first
Aug 30, 2008 | Minolta Dynax 505 35mm SLR Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon PowerShot A75 Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
