Question about Garden
Is the Makita dcs 6410 chainsaw a good one? i need
Is the Makita dcs 6410 chainsaw a good one? i need to replace a stihl farmboss but do not want to spend as much money. i have small jobs only
SOURCE: STIHL CHAINSAW MIXTURE SETTINGS
one turn high and low 66 has compesator carby willrun rich up high but will lean under load
Posted on Sep 03, 2008
muttandjeff
  • 359 Answers
SOURCE: i am trying to find the magneto gap for amakita dcs 340 petrol chainsaw
use a regular post card inserted bet fly wheel and mag close enough
Posted on Dec 05, 2008
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
SOURCE: Stihl Farmboss - cord will not move
try taking plug out to see if it turns then.if not take off pull cord assembley to see if something has come loose and jammed flywheel, failing that could possibly have snapped the piston ring and jammed. oh yes one last thing check clutch if you have chain brake on and clutch is jammed obviously wont turn.
Posted on Dec 24, 2009
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
Posted on Mar 26, 2010
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Chain Saw Stihl 290 Farmboss wont idle well
Check to see if the air filter is clean. If it is, increase the idle speed adjustment screw on the carburetor.
Feb 09, 2014 | Stihl Garden
Coil for o41 stihl farmboss chainsaw serial no. 5744323
Here is the full illustrated parts diagram.
Jul 14, 2013 | Garden
How to separate the crankcase on a Makita dcs 540 chainsaw?
You can see how to repair this saw in the Makita DCS540 Manual. It is around page 28 I think.
Feb 05, 2013 | Makita Dcs 540, 20" Chainsaw Chain 78dl...
Now spark on a stihl farmboss041 chainsaw
The best thing and not so cheap is to replace the points with a electronic ignition coil. We do this at our shop all the time.
Sep 26, 2012 | Stihl Garden
I have a stihl 041 farmboss and I am getting excessive bar oiling on the chain and bar. I was wondering if there is an ajustment to control the amount of lubrication to the chain and bar. Thanks Jim
Yes, but the location of the oiler is a secret.
An entire thread dedicated to your question follows (see post 5):
http://www.arboristsite.com/showthread.php?t=33705&highlight=041+oiler+adjustment
Please go here and request a manual. Please ask they add one that can downloaded too.
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 12, 2010 | Garden
I need a chain but cant find one in my area listed for dcs 6401 can I use one for another 20" model
7301 7901 9000 9019 use the same chains But all these can have three differant chains you need to match it with the bar you have.
Jan 08, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Stihl ms310 chainsaw will only run on choke
You actually need the adjustment tool,looks lie a small screwdriver with a smal socket at the end of it.
Jun 02, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
I am trying to find the magneto gap for amakita dcs 340 petrol chainsaw
Oct 05, 2008 | Makita Garden
Garden Logo
235 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
