Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My lamp busted. I just replaced it but the lamp light is still bl
Blinking and iys not turning on. Any help out there?
  • Mitsubishi Master
  • 8,617 Answers
Thats often caused by failed capacitors on both the DM and the Power boards. You can get the mitsubishi repair kit called the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which contains the parts and the CD with detailed instructions.
Posted on Jul 15, 2010
Engine backfires and check engine light blinks on and off loses power
the blinking is your code bl-bl-bl pause bl-bl this would be 32 count your flashes your backfire can be from anything like needing tune up,bad gas,or a component went bad code will help towards fixing truck
Aug 24, 2015 | 1993 Toyota Pickup
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
No Power to light on WD-73727...
This cable attaches to the lamp,reach in behind the lamp case in the tv and hold it in place and reinsert the lamp make sure it plugs into the lamp securely.
Aug 22, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Tv was on and shut itself off. it now wont turn on. the green power light comes on then clicks off after 1 or 2 seconds with no picture ever coming on
The lamp is busted. Check and replace. Contact your dealer for lamp replacement information. Dispose the busted lamp properly. It contains mercury. Call your local authorities for proper disposal.
Aug 02, 2009 | Mitsubishi WS-48313 48" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
287 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
