Question about Dometic RM2652 Refrigerator
My rm2652 is pluged in to 110volt, the freezer is working good but the lower freg is still warm. what can i check?
  • 478 Answers
Ounds as if the evaporator fan motor is not working. Listen for a fann inside ,if you herear it procdeed to 9nvistagat the defrost mode. Rem,ove the freezer back panel to look to see if it is frosted over. If so check the defrost strip, and advance the defrost timer until it clicks. watch to see it defrost if it does replace dedfrost timer.
Posted on Jul 15, 2010
New refrig 1 year old and it runs constantly. what can I do to correct this problem
if the freg make more ice the problem is th thermostat but if the freg run without good cooling thats mean you micro-gas leakage
Feb 12, 2015 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer works but not the refrigerator on rm2607
move temp sensor lower or let hang if ok then replace
Aug 02, 2013 | Dometic RM2652 Refrigerator
Freezer is 18 deg. F. Refer is 62 deg- seems too warm
freezer maybe frosted up not let cool air in refer .or the fan in freezer is not working
Sep 29, 2010 | Dometic RM2652 Refrigerator
The freezer work but the freg. a little warm
its normal for the frige to get warm just for a cople of houre and it will ajust....
Aug 02, 2010 | Amana ABB1927DE Bottom Freezer...
The freezer gets cold but the fridge does not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 28, 2010 | Dometic RM2652 Refrigerator
Frig won't cool RM2652
You'll need to get in touch with the store you bought it from but Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 26, 2010 | Dometic RM2652 Refrigerator
Why do i have water in my refridgerator
Air contains water particles and it will condense to form solid ic, you have to defrost your refridgerator on a regular basis and have to watch the water is drained up to the maximum extent
Dec 17, 2009 | Kenmore Refrigerators
Freg stopped cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
o
Jul 06, 2009 | True GDM-10PT Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Warm Refrigerator
if the freezer is ok it may need a full defrost. try that in the first instance then re use- if the same problem occurs it may be the stat.
Jun 14, 2007 | GALAXY Microsystems 63702 Top Freezer...
Dometic RM2652 Refrigerator Logo
225 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
