Question about Fisher and Paykel GWL11 Top Load Washer
I have a GW512 Pride washing machine that will not do anything for any more than a minute or two before the first light on the wash progress line and the second last light on the wash progress line both start flashing and it starts beeping and will go no further, it will not agitate or spin, the only thing that it will do is pump the water out for a short time
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now the fault you have indicated is called SINGLE ROTOR POSITION SENSOR ERROR. The ROTOR SENSOR is located underneath your machine attached to the motor.Its purpose is to tell the computer in what position the drum is and adjust the speed of the bowl.The other less common reasons for the fault will be faulty wiring to the ROTOR SENSOR or your MOTOR CONTROLLER IS FAULTY.To test the ROTOR SENSOR unfortunately you must have a test meter called an RPS tester.Or if you can get the machine to spin, once it is spinning open the lid quickly the bowl will stop and the ERROR CODE you indicated will show again on the wash progress lights. If you want to try and just change the ROTOR SENSOR without testing it I can guide you throe the process step by step.But remember the fault could be the MOTOR CONTROLLER.So changing the ROTOR SENOR will not rectify the problem. Please reply back on how you would like to proceed and I will try to find another way to test the ROTOR SENSOR for you.By the way do you have or can borrow an electrical test meter?This will help checking the wiring.Looking forward to your reply
Posted on Jul 15, 2010
Washing machine won't drain/spin
the program board is not progressing the wash cycle to drain / spin
call in a technician for a proper diagnosis and quote
Aug 02, 2016 | Washing Machines
Hi - I have a Fisher & Paykel GW512 washing machine. it keeps giving an error showing these light on the cycle progress 01000010 (code 66)? I pulled the top off and if I disconnect the display module from...
I can't remember what fault 66 is off hand, but I can check tomorrow.
fault 130 (which has one extra 0) is a common fault, and will do what you say. it is an intermittant RPS fault. RPS is a small chip on the side of the motor, and they are a little touchy at times. easy enough to replace by removing motor cover, loosening the motor and removing the RPS from it's harness.
Oct 20, 2013 | Fisher and Paykel Washing Machines
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Cold water intake just tricking
calcium build up clean inlet lines and screens
Jan 20, 2018 | Fisher and Paykel Washing Machines
Fisher and Paykel GW512 wont complete spin step.
This the lid lock device
If lid is open circuit, one of the wires have came off the plug.
Jul 19, 2012 | Fisher and Paykel Washing Machines
F&P GW512 compact wont spin
Hi just read your posting.Does your machine drain the water out?Starting from left to right what lights were lit on the progress bar when it started to beep?Was it the 2nd and 5th or 3rd and 7th---etc---?Please reply with additional information on the questions and I am sure I can help you rectify this fault.
Jul 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Top loader MW511 will not start. Wash Progress (where you select wash type eg long or short) is the only display with lights showing, and I cannot change anything despite pressing the button to do so. No...
Hi just read your posting.Now on that wash progress line of lights there are 8 lights in total.Starting from the far right what lights are lit up?Is it the 2nd and 5th or the 4th and 8th--etc---?With this additional information I can work out the error code and advise you how to repair this fault.Please reply for further help.
Jun 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel Pride 5.5kg washing machine, everything works fine until you get to the spin cycle and then it just beeps and won't do anything more. What can I do to check or fix this?
My washing machine will not cut off on a high water level, but will on the medium. It will wash until it gets to the short wash and then it just beeps at me. I tried to advance it to the rinse cycle but the light just blinks and won't do anything more. It did drain the water out though. What's the problem and how do I fix it.
Aug 05, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
108 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
