Question about Logitech Cordless Mouse
Does mouse have a battery? I cannot get the mouse to work.
    Scholar:
  • 70 Answers
Yes the mouse do have battery. You can remove the cover of the mouse and change the battery.
If you can forward the model number of your mouse I can guide you how to change the battery.
Posted on Jul 15, 2010
  • 553 Answers
All cordless mice have batteries. Usually you'll find a battery door on the bottom.
My ARC 1349 mouse doesn't work after I replaced the battery.... my mouse working well, but after the battery is empty and I replaced 2 New AAA battery, it doesn't show anything... no red light on the...
Try removing the batteries and leave it out for 5 minutes. Place the batteries back in and make sure that you hold the pair button and wait for the red lights to blink before trying to use it. See the link below for more detailed instructions. Pair Microsoft Arc Mouse Microsoft Accessories
Feb 20, 2018 | Microsoft ARC Mouse
Tip
Dell wireless mouse M787C batteries are wired in Parallel not in series...
Hello All, I just received a Dell All in One Computer with the M787c wireless mouse. I installed 2 fresh batteries and noticed after 3-4 minutes one of the batteries was getting warm? I removed that battery and the mouse LED light was still working. SO the M787c mouse was working as it should with only ONE Battery!
I checked wiring of the batteries and found that the Batteries were WIRED in Parallel. Wiring batteries in parallel is not a very good Electrical practice, at all!
I am sure that many owners of this mouse have gone through many batteries because of the miss wiring.
If you mouse does not work with properly with one battery if you are mechanically inclined you can disassemble the Mouse and rewire the batteries in SERIES.
There are 4 screws on the bottom of the mouse, 2 in the bottom underneath the front gliders, and 2 in the top. Happy fixing. Rob
on Feb 29, 2016 | Dell M787C Wireless Mouse P/N: M787C -...
The mouse has stopped working. I put new batterie...
the gear head wireless mouse i purchase for my netbook, does not work
May 20, 2010 | Apple Mouse
My mouse isn't working
Try to put new batteries.
Apr 30, 2017 | Logitech 931150 Mouse
My mouse was just working and all of a sudden it stopped, I changed the batteries, reset the small button on the bottom and also pushed the button on the plug in portion. Help Allen
I have a miscrosoft wireless laser mouse 6000, and it also stopped working on my laptop. I changed the battery, still not working. I tested the battery in another device, and it was good. I moved the mouse to another computer, and it did not work. The light on the usb connector was lit. [No changes at all to my laptop.]. It seemed like there was no power to the mouse, and I looked at the contacts inside the mouse. The contact just inside the battery opening appeared to be bent down away from the contact on the battery tray. So, I pulled it up a little so it would connect when the battery drawer closed, and (after tweaking it a couple of times), it finally worked!
Dec 08, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Mouse just quit working, installed new batteries red light works
Normal 0 Make sure that the batteries are good then do the following.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Dec 07, 2009 | Logitech Cordless Mouse
My mouse batteries died and since then hasnt worked.
check your batterys with a flashlight after that push the buton on your recever. then push the keyboad reset and last do the mouse. if that don't do it switch and do the mouse first then the key board. keep close to the recever it works better
Aug 04, 2009 | Lenovo Mini Wireless Laser N10 Mouse
I have a logitech which used to work with window vista home premium 64 bits version. Today it is not connecting although i replaced the batteries and the light in the back of the mouse is dim and sometimes...
THE MFG MAY HAVE A CERTAIN BATTERY REQUIRMENT, NEED TO GO LINE AND LOOK UP THAT INFORMATION, DEPENDING ON THE MFG AND THE BATTERY COMPANY THEY WANT YOU TO USE IF YOU DONT USE THERE BATTERY REQUEST THAN YOU WILL END UP BUYING A NEW KEYBOARD OR MOUSE WHEN THE BATTERIES RUN LOW.
LOOK FOR A LITTLE PIN HOLE ON THE BOTTUM OF THE MOUSE ALSO EVERY TIME YOU CHANGE THE BATTERY YOU LOOSE THE FREQUENCE THE MOUSE USES, SO DEPRESS THE BUTTON UNTIL THE COMPUTER SAYS IT HAS FOUND A NEW PIECE OF HARDWARE, THAN THE MOUSE SHOULD WORK FINE.
GO ON LINE AND SEE IF THERE ARE ANY NEW UPDATE FOR THE MOUSE
RODGANDYSR
Mar 05, 2009 | Logitech Cordless Mouse
Logitech wireless mouse
Went onto laptop today and mouse is working - don't know why !
Sep 10, 2008 | Logitech Cordless Mouse
Logitech Cordless Mouse Logo
592 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
