Question about One For All URC4220 Remote Control
Need codes for toshisba md13m1 - One For All URC4220 Remote Control
Pin codes for **** at www.movieunlock.com movie i.d. 41941
need a pincode for bonus scenes id #41822 movieunlock.com
Apr 11, 2014 | Cameras
How do I connect a Toshisba soundbar?
Your sound bar should have some sort of HDMI IN and HDMI OUT. This means that there are at least one place to plug a HDMI cable into the bar from either your dish or bluray player and then you take another HDMI cable and plug it into the port labeled HDMI OUT and this will plug into your TV either in HDMI1, HDMI2, or HDMI3 and then it will provide sound for the device. Unfortunately you didn't not list the item so I can not look it up to see if it can accept multiple devices so if it only has two HDMI ports then it can only support one device and you will have to manually change out devices through the HDMI IN port. Essentially the soundbar is just a pass though and takes the sound and sends the picture to the tv.
Jun 03, 2013 | Sanyo Dp55441 TV
Need manual for md13m3p
see answer just posted for this from me.
Oct 29, 2012 | Toshiba MD13M1 13 in. TV/DVD Combo
Would like to know if my toshiba model 20AF46 will need a converter box fo receive digital signal?
Yes you will need a converter box. This television does not have a digital tuner. It does not have an atsc tuner. It does not have a qam tuner.
Sep 14, 2011 | Toshiba MD13M1 13 in. TV/DVD Combo
Toshisba laptop wont swith on tried swithing a charger and battery still no change nothing happens
If you have tried a new charging cable and a new battery that kind of narrows it down to the power button being faulty.
Aug 30, 2009 | Toshiba Satellite Pro L300 Notebook
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Boot failure
Hi
did you updated the bios before this problem ?
do you hear any beep ?
did you add a new hardwarw to your laptop?
answers for this will help to solving this isue
Dec 11, 2008 | Toshiba Satellite A135-S4527 Notebook
Hardware or software problem on laptop
Need the Toshisba WinXP Recovery CD for a Toshiba P15.
Where?
when?
Who?
How Much.?
DocCpu@GMail.Com
Apr 03, 2008 | Computers & Internet
Lost remote, cannot disable SAP
You can use a universal remote, but it's a little tricky. I have a phillips universal remote and I have to keep switching between 2 codes to get the menu up and then navigate through. There is nothing on the TV to fix it.
Feb 20, 2008 | Toshiba MD13M1 13 in. TV/DVD Combo
Unit shuts off automatically after power on.
You have an internal short in the electrical line. your wall a/c [120 volts] goes inside and is converted [changed] to DC [ like a super battery] There are a lot of connections coming out of this POWER SUPPLY[super battery] to FEED other electrical circuit. ANY one of the circuits can demand more then power supply can give and will cause it to SHUT DOWN [turn off to protect itself]
unless u know what u are doing [" DANGER!! wILL rOBINSON, DANGER!!] you should not mess with it.
Jan 19, 2008 | Toshiba MD13M1 13 in. TV/DVD Combo
One For All URC4220 Remote Control Logo
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
