Need Manual - Friedrich Climate Master Geothermal Heat Pump 805
Need Friedrich Climate Master Geothermal Heat Pump manual for Model 805 which was manufactured in 1980s.
5 Suggested Answers
  • 85 Answers
SOURCE: heat pump doesnt turn on when calling for heat
Make sure your power source is still supplying power. Breaker box, maybe you have another too many appliances hooked up to same circuit? If that does not work, get advise from your local distributer before having a small appliance tech charge you for the issue.
Posted on Dec 05, 2008
  • 20 Answers
SOURCE: york affinity heat pump installation manual
Go to WWW.YorkUPG.com and search for your model. Should be in the downloads section
Posted on Sep 01, 2009
ginko
  • 19396 Answers
SOURCE: need a wiring diagram for
Hi.
The manual for TEC12K00rtc is not available. The number may be incorrect or the manual may not be available in PDF format. If the model number is correct contact Friedrich air conditioning, in that case the manual may have only be made available on paper. See: Contact Us ' Friedrich Air Conditioning
Here all service manuals available for Friedrich. The TEC12K00rtc is probably part of Wallmaster series, wiring should be the same as shown in first manual
Wallmaster Series.
Wallmaster R
Service Manual - Master
P Series Service Manual - Friedrich Air Conditioning
Service Manual - Friedrich Air Conditioning 2003
2000 TwinTemp® J Series
RAC-Svc 07 (4-07).indd
RAC Standard Chassis IO_(06-10-10)_CS3.indd
CP08F10 Service and Parts Manual ' Sylvane
C-90B Service and Repair Manual
ZStarTM
Air Conditioner Service Manual 2007
Posted on May 13, 2011
I working on a old Friedrich water source heat pump Model # V42 does anyone knows what size is it?
The friedrich name was taken off of units in the 80's when the climatemaster name was invented. My guess is 42000 btu or 3.5 tons rated capacity
Feb 05, 2015 | Friedrich Heating & Cooling
Tip
Underfloor Radiant Heating works great with a Geothermal Heat Pump
Radiant floor heating has been the standard for comfort and efficiency for many years. The feeling of having a warm floor under your bare feet is priceless. Rolling on the floor while playing with your children or grandchildren is great when it is cold outside and the floor is pleasantly warm.
Geothermal Heat Pumps usually are associated with hot air heating and air conditioning systems. If you live in a climate that very seldom needs air conditioning, then you need to concentrate more on the heating. There is a super way to use geothermal technology to give you very efficient and comfortable heating. Underfloor radiant heating can very easily be incorporated with a geothermal heat pump to give you the best of both comfort and efficiency.
Here are some thing’s that you do have to consider before deciding on a system like this.
You will need to drill a few wells to extract the heat from the ground.
Piping must be installed in the wells correctly for the system to work properly.
You will need a heat pump designed for hot water heating.
You can not use a heat pump that is designed for hot air use and convert it for radiant heating.
The radiant heat design must be designed to use water temperatures that are cooler than that of many radiant heat systems.
The maximum temperature design should be 130 degrees F.
To get this kind of design to work correctly for you, you will need to use good quality heat plates and insulated under the heat plates.
By following these guidelines I have designed a number of radiant heating systems that have proven to heat houses very comfortably at temperatures well below zero.
If you decide on installing this type of system make sure that your installer knows exactly what they are doing. This type of system requires many things to be done exactly right, so that the water flows will allow the system to work correctly. The piping on the well side is extremely critical so that it uses all the wells equally. On the house side the piped using a primary/secondary piping scheme. Pumps and pipe sizes need to be able to give you very high flow rates so that the temperature drop is kept to ten degrees or less. When working with these low temperatures the piping and pumping becomes so much more critical.
By using these principles you can combine two very great heating types and can have a very good heating system that will perform very well for many years. The main drawback with this type of system is that you do not have the ability to get much cooling from this system. This is probably the only drawback of this type of system. It would be wondeful if there was a geothermal unit that was heating only. The elimination of the reversing valve would be a great cost savings and a plus overall. This system is best suited for cooler climates that require little or no air conditioning.
on Dec 05, 2009 | Heating & Cooling
Tip
Geothermal Heat Pumps And Radiant Heating - An Absolutely Fabulous Combination
Geothermal Heat Pumps are usually associated with hot air heating and air conditioning. In climates that very seldom need air conditioning you need to concentrate more on heating. There is a very good way to use geothermal technology for very efficient and comfortable heating. Radiant floor heating can very easily be combined with a geothermal heat pump to give both comfort and efficiency.
Radiant floor heating has been the comfort and efficiency standard for many years. The feeling of a warm floor under your feet is priceless. Romping on the floor while playing with the children is great when the snow is blowing and the floor is pleasantly warm.
Geothermal heating has also been known for it's efficiency also. The drawback to hot air geothermal heating has been the air temperatures that are cooler than normal hot air heating systems. By combining the two types of systems you can have very comfortable heat and efficiency at the same time.
There are something’s that you do have to take into consideration before deciding on a system like this.
You will have to drill a few wells to extract the heat from the ground. The piping must be installing in the wells correctly for the system to work properly. The heat pump needs to be designed for hot water heating. You can not use a heat pump designed for hot air use and make it work for radiant heating. The radiant heat design must be figured to use water temperatures that are cooler than many radiant heat systems. A maximum temperature design should be 130 degrees F. To get this kind of design to work correctly you will have to use good quality heat plates and insulated under the heat plates. By following these guidelines I have designed systems that have heated houses very comfortably at temperatures well below zero.
If you decide to install this type of system make sure that the installer knows exactly what they are doing. This type of system requires many things to be done exactly right so that the water flows will allow the system to work correctly. The piping on the well side is very critical that it uses all the wells equally. On the house side the piping must be primary/secondary. Pumps and pipe sizes must be able to give very high flow rates so that temperature drop is kept to ten degrees or less. When working with such low temperature the piping and pumping becomes so much more critical.
By using these principles to combine two very great heating types you can have a very good heating system that perform very well for many years. The only other factor with this type of system is that you don not have the ability to get cooling from the system. That is probably the only drawback of this type of system. It would be great if there was a geothermal unit made that was heating only. The elimination of the reversing valve would be a cost savings and a plus overall. This system is best suited for cooler climates that require little or no air conditioning.
on Dec 04, 2009 | Heating & Cooling
Tracer summit system
Depending on the system yes it should work.
Jan 21, 2015 | ClimateMaster 1120-431 Thermostat...
Yourhome honeywell com
To start, most tstats pull straight off of its base, or pull away from the bottom and lift from the top. Yours should be a touch screen and pulls straight out. Hopefully the installer secured the base well enough to the wall. At the tstat that has dehum. capability, see if it has a terminal marked D or H for dehum. If so, there is a wire connected. Now at the 1 you would like to replace, remove tstat from base, and check the number of wires you have available. If you don't have a "spare" wire for the new tstats' H(humidity) terminal, it won't work out because you'll need an extra wire. Also the existing tstat may have that option, but isn't configured for dehumidification. Might check that too. It is possible to add dehumidification to any and all zones depending on available wires. Also, at the geothermal, this "extra" wire needs to be connected.
Mar 10, 2017 | Heating & Cooling
NEED A MANUAL FOR A MIDLAND CB MODEL 77-805,AND A MIC
You can download it at www.cbtricks.com ....hope this was helpful...
May 15, 2010 | Radio Communications
I have a very old manual Chronotherm thermostat.
No. The clock is just the set back timer. Pull the battery and use the stat manually.
Jan 26, 2010 | Honeywell Electronic Programmable...
Ptac heating problem
This is the service manual for this system. It might give you an idea on what the problem could be. Page 27 should be your area to start. There are two for the PTAC series. I'm not sure which one will pertain to you.
http://www.friedrich.com/downloads/PTAC_Service_P-Series.pdf
http://www.friedrich.com/downloads/PTAC_Service_PD-Series.pdf
Mar 22, 2009 | Fedders AED24E7F Wall/Window Air...
Heat pump doesnt turn on when calling for heat
Dec 05, 2008 | Friedrich YL24J35D HEAT COOL 24000 BTU 230...
Heating & Cooling Logo
656 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
