Question about Poulan "Poulan" Push Mower
Pull cord stuck
The pull cord will not budge. Any ideas?
  • 755 Answers
First. Remove the spark plug and see if any oil runs out.
Second, If the cylinder isnt flooded with fuel or oil. Make sure your blade brake is releasing properly.
Third. Remove the pull starter cover and consider putting a very light spray of WD40 onto the spring housing from the underside and work it around.....the recoil spring may just be rusted solid and a little lube and maybe a tap or too with a rubber mallet might just break it free.
I have seen all three conditions turn an otherwise working mower into something that wouldnt budge.
Good luck and be careful. Dont pull out the recoil spring as it under tension and could spring out and bite you or at least make a mess.
Posted on Jul 19, 2010
Stanley chipper shredder pull cord is stuck. It has a back-up electric start, which also won't work. The engine sounds frozen.
sounds like something may have jammed the engine! it may be worth taking the pull cord of and then trying to turn engine with a pair of plyers
Apr 08, 2017 | Electric Garden
HELP! My Stihl TS400 pull starter is stuck or seized as it won't budge an inch when I try and pull it. Is there anything I can try to free off the pulley or does it mean it is seized and not worth fix
You may get a compression lock of some kind on these engines sometimes (2 stroke and 4 stroke) and I have had this happen a couple of times when trying to start them thinking that the mechanism had seized up when it had not. You pull the cord and it locks solid. You cannot turn the engine over. I have always managed to eventually free it though.
What I would do in your case is remove the spark plug and then see if you can pull the starter cord.
Dec 28, 2015 | Stihl Saws
U tube chainsaw pull cord wont pull start
Some saws with autotmatic oiling will leak bar oil into the cylinder and cause this. Pull out the spark plug and hold the saw so the oil runs out of the spark plug hole. Pull the starter cord till no more oil sprays out of the hole.Clean the oil off the plug and start your saw. It will smoke more than normal till the extra oil is burned out.
Sep 05, 2014 | Homelite Garden
How to fix Mower cord stuck after hitting rock?
Pull the plug. MAKE SURE THE PLUG IS COMPLETLY REMOVED AND SEPARATED FROM THE MOWER!! Remove the cover with the pull start attached. see if you can turn it by the flywheel or the blade. If you can, you can just have the rewind repaired.
If not, then you have a probable bent or twisted crankshaft. Most likely not worth repair.
May 16, 2014 | Electric Lawn Mower
Honda water pump, wb20x/wb30x Left water in it over the summer, now the start pull cord wont budge, suspect corrosion,can I fix this myself, I really need this pump next spring, only been used this 1...
Remove the spark plug, this will rule out hydrostatic load on the engine. Try to pull it again. If it is still stuck, You will need to try to turn the pump.
Make sure there is engine oil too.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 03, 2010 | Honda Plumbing
Phil & Teds front wheel locked and won't budge
you should be able to pull the knob out and turn it to the possition spray some lubricating oil first if it stuck. But it will pull out. Go to www.buggypitstop.co.uk if you need any spare and advive on how to fit your pushchair
Feb 02, 2010 | Regal Lager Phil & Teds Sport Buggy Single...
Stihl Farmboss - cord will not move
try taking plug out to see if it turns then.if not take off pull cord assembley to see if something has come loose and jammed flywheel, failing that could possibly have snapped the piston ring and jammed. oh yes one last thing check clutch if you have chain brake on and clutch is jammed obviously wont turn.
Dec 21, 2009 | Garden
Pull cord won't pull
Check the shaft to see if there is something stuck in there. You can pull the wire shaft out to check. It is wire but looks like a small cable. Good luck...Lee
Aug 27, 2009 | Garden
I have a briggs and stratton lawn mower ad the pull-cord is stuck
make sure nothing is jammed around the blades...if thats ok, remove the pull cord housing and try and spin the engine. if it doesnt turn, the motor is locked up and needs repaired
Jul 10, 2009 | Garden
Husqvarna 51 from 1991 too much resistance to starting attempts
It sounds like it's sorta gummed up from old gas residue. You could spray carb cleaner in the spark plug hole and into the carb while holding the throttle open and pull the cord several times and then follow that with penetrating oil to re-lubricate the engine. You're probably going to have problems with the carb also. I would have it rebuilt or, better yet, purchase a new one
Jul 01, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan "Poulan" Push Mower Logo
380 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Poulan Garden Expert? Answer questions, earn points and help others
