Question about Dometic RM2652 Refrigerator
Fridge works on gas...but not on AC
Heating element is heating up but not circulating refridgerent. RV is level, getting 120v to the element, 95 ohms through the heating tube(which is new). Switch fridge to gas and it starts gettting cold with in an hour. Haven't checked the roof vent for blockage as it has been working on AC up to last weekend. Had the same problem last year and replaced the thermoster and AC element last year too. Installed a new dinasor controller last year. Have only had RV for two years but have had nothing but problems with the AC side of the fridge. Element does not seem to be getting hot enough?? RV is a 2005 Terry
  • 905 Answers
Your heater should measure 44 ohms, give or take 10%.
95 Ohms is way off. The RM2310 uses a 92 ohm heating element, perhaps you installed / were sold the wrong heating element?
Posted on Jul 18, 2010
I have a tedco gas electric fridge. Works fine on gas but when i switch over to electric-no go. It says it is a 12Volt 12 Amp system and has a standard plug at the rear which I plug into an electical...
there should be a small black box transformer wired into the ac cord
that goes to your standard plug
the transformer should then have wires going to your heating element
If someone has removed the transformer just order a 110vac to 12v 12 amp transformer and wire it in like you would a doorbell
when the transformer is working you should feel heat at the rear of your refrigerator at the heating element
Nov 20, 2013 | RVs
Dometic RM2652. The fridge will not work when it is plugged into AC.
Unplug the fridge. Remove the cover from the circuit board, unplug the 2 wires going to the heat element and do an Ohms reading should be 35-45 Ohms. If the Ohms is good then you need a circuit board as long as you have checked the 110 volt fuse on the circuit board.
Apr 30, 2012 | Dometic RM2652 Refrigerator
Electric Travel Cooker, Sanyo RN-AVA308, will not heat up, where can I have it serviced?
I have the same unit and the same model number. Mine also not heat up. upon investigation I noticed the heating element has a 4 wires which I believe each pair (2 wires) meant for 100/120V and the other one is for 220/240V. I checked 2 wires (1 pair) has an open circuit while the other pair is ok. I directly connected the heating element to the power and it was heated up. I measured the resistance and it was around 78 ohm. from my lame calculation this is for 100/120V heating element. the 220/240V was busted.
Since mine on 220/240V power grid, to use the working 78 ohm heating element the estimated power would be P=VxV/R, around 738W which is way too high than the rated power (365W) for this voltage. I plan to add the dummy resistor 82 ohm + 78 ohm heating element to reduce its power around 370W. Hope it works.
Mar 23, 2011 | Kitchen Appliances - Others
The heating is not working.changed fuse,still nothing
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position. If still noheat, check your heating sensor for closed circuit by an OHMs metre.It it'swith RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 19, 2011 | Heating & Cooling
I have a heating and air unit. the air conditioner works and the fan will work. but when i turn on the heater it will not ignite. i have checked the thermostat and it sends the signal to the unit to turn...
To get proper heat, keep your temp setting at 30+ degreeand also mode in "heat "position. If still no heat, check your heating sensorfor closed circuit by an OHMs metre.It it's with RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 13, 2011 | Heating & Cooling
I had a new American Standard 1.5 ton electric AC/Heater put in this past July. This is the first really cold days we have had in Texas and I have noticed it is blowing cold air when in heat mode. I have...
Dometic RM2652 RV Refrigerator trips GFCI
Hi!!
Right beside the circuit panel, there is a grill, remove the 4 screws to gain access to the transformer/battery charger. You'll see a double power outlet, one cord is from fridge, the other is from the transformer. UNPLUG Transformer cord and reset breaker.
It will take a couple of minutes for the fridge to change to AC if you have it in AUTO. If everything works fine, REPAIR OR REPLACE TRANSFORMER/BATTERY CHARGER.
Don't forget to rate this answer, Good Luck!!!
Apr 19, 2010 | Dometic RM2652 Refrigerator
Freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Aug 19, 2009 | Refrigerators
Dometic RM7291L not effectively cooling on 240V but fine on gas
On the back of the unit, at the bottom, there should be a panel that is removable. Inside should be a fan, the condenser coil, and the compressor. The fan has to be constantly blowing air over the condenser coil, to dissipate the heat (which it is essentially being removed from the refrigerator by the compressor)
When the entire fridge stops cooling, one of three things have happened. The fan isn't removing the heat from the coil, or the compressor isn't compressing the freon, or the freon has somehow leaked out of the system. If it is the fan, you have an easy do it yourself repair. If it is the compressor or the freon, you will probably (but not necessarily) need a professional.
Inside the fridge, there is a coil that is cold instead of hot. A fan must continually blow over that one too, to circulate the air over the cold coils. The fan usually only works when the doors are closed, so be sure to have the door switch pressed to "shut" when checking it.
Check those and post back. And, I know... it really is Dometic.
If the problem is the first one,
Jul 28, 2009 | Dometic RM2620 Refrigerator
Dometic RM2652 Refrigerator Logo
764 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
