Question about Samsung Televison & Video
My samsung flat screen...keep shutting down why?
Hi ladytuts.
One reason may be that you don't have the tv plugged into a surge suppresor. If you don't have one, its advisable to get one, as lcd's/plasmas are quite susceptible to small power spikes.
Try unplugging the tv for one hour, then plug it in and see if the tv corrects its own issues.
If that does not resolve the issue, pay attention to the number of times the power light blinks before shutting off. Thats usually a 'fault code' for troubleshooting a more indepth problem with the machine.
Posted on Jul 15, 2010
2 Suggested Answers
SOURCE: tv keeps shutting off and going back on by itself
Faulty parts on PS board , bad press for Samsung
When checking the capacitors, If they are slightly rounded on the top where the X is, the cap is defective.
Because the Samsung LNS4051D would not turn on and the power
LED would blink 4 times and the relay would click and this
would repeat again and again. I replaced power supply board
parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors,
three had their tops bulged up slightly that I missed on
initial visual inspection. After seeing the reports of
problems with these caps on
http://www.fixya.com/support/t1336881-will_not_turn_or_off ,
I replaced them with Radio Shack part 272-1032, 1000 uf, 35v.
They are slightly bigger, but fit OK. TV is working fine now.
Cost was 4 x $1.59 = $6.36 plus the time. I saved between
$100 to 300 in the process of either replacing the board or
getting the unit serviced. If you are not comfortable
replacing components which means using a soldering iron, you
can replace the power circuit board, available from
www.Samsung.PartStore.com.
Some UTube showing the problem and fix
http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related
http://www.youtube.com/watch?v=Mm51C_RDIZE&feature=related
http://www.youtube.com/watch?v=BNHHrgX_6cs&NR=1
Posted on May 27, 2010
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Immediate shut down
Check the capacitors on the Y board. Otherwise replace the board
Jun 20, 2015 | Samsung Pn60e550 60" 1080p Plasma Flat...
I have a 61 inch samsung TV. A message flashed across the screen saying "check fan # 1 " then a few minutes later it shut down.
Hello
Not much to do by web, this message mean you most likely need a new fan, tv shuts down due to overheating. Contact service.
Aug 21, 2011 | Samsung Televison & Video
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
Hi. I have a bright streak going down the front
Ok, this is a classic LCD fault, unfortunately, your Screen "Element" has gone faulty. There is NO repair, replacement of said "Element" IE: The LCD Screen. This is an expensive repair. In my professional opinion, you need to take it to a Samsung, authorised, service venter, then ask for a "Quote" for repair, that way you can be appraised of costings and you can determine as to repair or replace.
Apr 28, 2010 | Samsung LN-S4051D 40 in. LCD Television
42 samsung plasma tv
Need to get service from A/S center for replace PDP module.
Jan 25, 2009 | Samsung 52 in. LCD Flat-Panel HDTV
Televison & Video Logo
116 people viewed this question
Jerry Greenberg
Jerry Greenberg
