Question about Canon imageRUNNER 5000 Copier
DC control don't reset - Canon imageRUNNER 5000 Copier
  • 31 Answers
Ram chip may be bad. replace
Posted on Jul 16, 2010
Reset service code
take negative out from battery 10 secont and put back
Sep 03, 2012 | Cars & Trucks
Tip
ERROR codesCanon 7050
Canon 7050 E000 Heater (Reset by unplugging machine) E001 Heater triac, DC controller, AC driver (reset by unplugging) E005 Fuser cleaner belt at end. Replace. E010 Main motor, DC controller or DC driver board E011 Any motor ( main, scan, cleaner belt, duplex, toner, lens) DC driver, DC controller, duplex driver board. E020 Toner out signal has been sent for at least 3 minutes E050 Duplex E203 Scan motor, DC driver, DC controller E210 Lens home sensor not actuated or won't deactuate E240 Controller board E241 Controller board E242 Controller board E400 DC controller, Doc. Feeder board, 24V power supply E500 DC controller, sorter board, 24V power supply
on Jan 19, 2010 | Office Equipment & Supplies
Getting error code e000050000 - what is this?
Main Cause: The fixing web has been taken up. The fixing web length sensor (PS45) is
faulty. The DC controller PCB is faulty.
Fixing web
1) Is the fixing web taken up?
YES: Replace the web with a new one.
Service mode
2) After replacing the fixing web, has the fixing web counter been reset
in service mode (COPIER>COUNTER>MISC>FIX-WEB) ?
NO: Reset the counter.
Fixing web length detecting lever.
3) Is the position of the web length detecting lever correct?
YES: Correct the position of the lever.
Fixing web length sensor (PS45), DC controller PCB
4) Is the fixing web length sensor normal? (See the instructions on
how to check the photointerrupters.)
NO: Replace the sensor.
YES: Replace the DC controller PCB.
Feb 04, 2011 | Canon imageRUNNER 5000 Copier
Belt will not start up and move.
The single most cause of no motor output is failure of the DC motor control. Look for any test lights on the power boards beneath the motor hood. Use caution when removing the motor hood because you may still have electricity ( capacitors are charged) in the motor area even if the treadmill is unplugged.
If you have a multimeter, you can test to make sure you have DC output from the controller spades ( Drive Motor Connectors) by clipping on them and then pressing the start key you should have a DC voltage reading if not the controller board is defective.
The motor can be tested by using a simple DC cordless drill or lantern battery this will turn the motor if the motor is good the controller board will need replacement , if not their won't be any belt moment the problem is the motor then the motor will need to be replaced. ( if you don' t have a multi meter this method of testing simple and easy)
May 14, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Error msg E197 Cannon imagerunner 1023N
This is a dc controller or image processor pcb communication error, reset all connecters on both boards,if error still their replace DC controller
Oct 16, 2009 | Canon Office Equipment & Supplies
Need your help
The problem with this code is in the fuser area. I don't have the specific manual for this model, but here's some information from a Canon IR3250 manual: III . Troubleshooting Malfunctions A. Error Codes 1. E000/E003 Thermistor 1) Is the thermistor soiled? YES: Clean the thermistor. Is the thermistor in even contact with the fixing upper roller? NO: Mount the thermistor correctly. Turn off the power switch, and remove the fixing assembly. Measure the resistance between connectors J50B-2 (FSRTH) and J50B- 3 (GNDTH) on the fixing assembly side. Is it between 120k and 290k W? NO: Check the wiring from J222 on the DC controller PCB to the thermistor; if normal, replace the thermistor. Main heater 2) With the fixing assembly removed, is there electrical continuity between connectors J50-3 (FSRN1) and J50-5 (FSRL1) on the fixing assembly side? NO: Replace the main heater. Sub heater 3) With the fixing assembly removed, is there electrical continuity between connectors J50-4 (FSRN2) and J50-5 (FSRL2) on the fixing assembly side? NO: Replace the sub heater. Thermal switch, DC controller PCB 4) Remove the fixing assembly, and detach the wiring cover. Is there electrical continuity between the terminals of the thermal switch? NO: Replace the thermal switch. YES: Replace the DC controller PCB. CHAPTER 4 TROUBLESHOOTING COPYRIGHT © 2000 CANON INC. CANON iR3250 REV.0 JUNE 2000 PRINTED IN JAPAN (IMPRIME AU JAPON) 4-43 2. E001 Thermistor 1) Turn off the power switch, and remove the fixing assembly. Then, measure the resistance between connectors J50B-2 (FSRTH) and J50B-3 (GNDTH) of the fixing assembly side. Is the resistance 1k W or less? NO: Check the wiring from J222 on the DC controller PCB to the thermistor; if normal, replace the thermistor. Power supply assembly, DC controller PCB 2) Replace the power supply assembly. Is the problem corrected? YES: End. NO: Replace the DC controller PCB. 3. E009 Fixing assembly 1) Is the fixing assembly rated at a voltage different from that of the power supply? YES: Replace the fixing assembly so that its voltage matches the fixing assembly. Power supply assembly, DC controller PCB 2) Replace the power supply assembly. Is the problem corrected? YES: End. NO: Replace the DC controller PCB. 4. E010/E011 Connector 1) Is connector J12 of the main motor and connector J218 on the DC controller PCB connected correctly? YES: Connect them correctly. CHAPTER
Jul 02, 2007 | Canon imageRUNNER 3570 Copier
Canon imageRUNNER 5000 Copier Logo
old marine
old marine
