Question about Sta Rite Sta Rite Above Ground Sand Filter with Multi Port Valve 21" Tank
Hello, i have an ultra jet by vicco powered by ge Model #PUULSCAS10948GR and i just got it off the interent because it said it was used on a pool or spa, its a 1 hrs power, well i cant even get it to turn on when i plug it in, it says bonding jumper required from motor to metaillic plumbing, i noticed that it has a copper peice on top with 2 screws on it, I really dont know much at all about this, i guess i should of researched before buying but it was a great deal, can u tell me what a bonding jumper is and where to get one, how to install please...thanks
  • Holly Potter
    Holly Potter Jul 15, 2010
    i dont know what u mean at all can u explain please?....whats a bonding jumper? and where do i get one, umm and where do i connect it to, where the cpper is on top of the motor? then where does it go from there Will the motor come on at all if this isnt done, because when i plug it up it doesnt come on at all, please anser all questions please
  • Holly Potter
    also whats a clad water pipe...sorry nver had to deal with this before my last pump u plugged in and thats all
  • 1,889 Answers
All you need is to connect the bonding (ground) jumper wire to a clod water pipe.
Posted on Jul 15, 2010
  • Jim Goldsmith
    Jim Goldsmith Jul 15, 2010
    Sorry. typo: should read "cold water pipe"
Change the battery for the jet 3
Hello Judy,please follow this link:http://youtu.be/J3iWrQ2gdvI.I hope this helped you
Feb 02, 2015 | Jet 3 Ultra Power Chair
How do you remove side and back jets on tub to clean
I seen two tpyes one where the inter jet unscrew and the other where the outter ring unscrews not sure what kind you have . Went to the pool store and they had a cleaner you add to the water and then run the unit for about 20 minutes then drain . It seem to work pretty good and there was less hassel taking the jets apart
Mar 05, 2012 | American Standard Home
I require a backrest with a headrest for a jet 3 ultra power chair
well ,This head rest you are wanting only comes on the captains seat model , Look for a captain seat back,make when you do find one that it came off a jazzy /jet 3 and that the seat with is the same as yours they should be universal a easy swapout of the back.
Good luck,hope i was helpful.
Jan 19, 2011 | Jet 3 Ultra Power Chair
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
I plugged in a spa/swimming pool motor/pump with water hooked to it as to not run it dry and it does not come on. Is it bad or how can I tell if it is bad. The motor is a GE. The pump unit is called ULTRA...
What did you plug it in to? Is it a cord or receptacle? Is there a reset button on the motor? Is the receptacle a GFI? Did you try to plug something else in there to see if it works? Check the breaker. You don't have to worry about running it dry, a couple seconds to test it won't hurt it. Most pool pumps are all plastic and they run for days dry, check it out.
Jun 08, 2010 | Home
Pumps Capacity?
# Aboveground filter systems and small inground pools (under 10,000 gals) should use a Low Head pump like a Maxim, or Dynamo or Power-Flo. # Pools from 10,000-20,000 gals can use a Medium Head pump like a SuperPump, a Pinnacle or Cygnet. # Pools over 20,000 gals could possibly use the High Head pumps like, Super II, Challenger, Ultra-Flo or the Sta-Rite pumps. # Pool/ Spa combos with at least 3 lines influent and 2 - 3 back to the pool, 2" plumbing may be able to handle the Ultra High Head pumps like NorthStar and the WhisperFlo
Aug 27, 2008 | Hayward 2 Hp Max-Flo Swimming Pool Pump...
Sta Rite Sta  Rite Above  Ground Sand Filter with Multi  Port Valve  21" Tank Logo
42 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
