Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Clean water is dripping into the washer constantly from the intake hose. When I come home at night, there is water laying in the bottom of the washer. I can see the water dripping from where it normally fills. What is causing this and how can I stop it? Thanks,
    President:
  • 670 Answers
There is an water inlet valve that controls the amount of water that enters the washing machine. Just like a faucet for your sink. It needs to be replaced and can be found an any appliance part supply.
Posted on Jul 15, 2010
    Sergeant:
  • 222 Answers
Changing the water valve will solve this problem
Posted on Dec 17, 2011
Maytag clothes washer model 2500 aae leaks along bottom edge
Sounds like a hose leak inside the machine. Possibly remover front bottom cover then check all hose connections.
Nov 14, 2013 | Maytag Washing Machines
Water drips out
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa!!
Nov 20, 2010 | Kenmore 23822 Top Load Washer
I have a leak coming from the bottom of my Kenmore 24722. All hoses and connections are sealed properly and are not leaking. The leak looks like it is coming from the gearcase towards the front bottom...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 20, 2010 | Kenmore 24722 Top Load Washer
Water dripping from the top near the water inlet connectors. can feel the dripping water falling on my hand when placed in the opening half way down the back of the machine. how do I get into the upper...
Hi. The most likely source of a leak that you can feel is the hose washer where it connects to the washer, if it leaks constantly. I use a mirror to peer behind stuff, and it works pretty well. The easiest way to confirm this is to slide the machine out far enough to see it in action (leaking, that is). Channel locks will usually tighten up the hose, but if the hose and hose washers are old, you should replace the washer. The washer is the same as those used in garden hoses, and can be found at any hardware store. Manuals can be found at the bottom of the FixYa page.
Best regards, --W/D-- please feel free to rate this solution - thanx!
Aug 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Started leaking from the bottom don't know where
Apr 30, 2009 | Washing Machines
Water is draining from bottom
Mar 29, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Leaky Gibson Front Loader
Jan 24, 2009 | Washing Machines
I have a whirlpool clean touch heavy duty washing machine that is leaking water out of the bottom. The hoses look like they are ok but there is a white colored corrosive looking material on what looks...
Jan 10, 2009 | Washing Machines
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal De
