Question about Microsoft MS Windows XP Professional SP2
What makes a mouse to continue to freeze. - Microsoft MS Windows XP Professional SP2
  • Scott
    Scott Jul 15, 2010
    What are you actually doing at the time it freezes? Sounds like some program is putting a load of stress on the CPU
  • pagev8 Jul 15, 2010
    I'm simply using my computer mouse as usual. I'm not doing anything to make it freeze. This morning after turning my computer on, about two minutes later it begin to freeze. Fortunately, after a few seconds it did not freeze but it did stall for a moment.
  • 60 Answers
Low memory and less processing speed . Try to upgrade your system
Posted on Jul 17, 2010
Scrolling keeps freezing
If this does it with fresh batteries and optical light is clean, also test on a solid colored surface before trying another mouse to see if it is the mouse or system board. Did this start with new download of another web browser? Software install/update? If mouse is older, need to remove ball and clean 3 wheels.
Aug 22, 2014 | Dell Computers & Internet
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
Easynote laptop continuos beep
your laptop RAM has been faulty.pls replace it.
Aug 21, 2009 | Computers & Internet
Mouse quits
go onto the support page for the pc you have. ex: if you have dell go to www.dell.com then go to the support section. from there look for mouse/touchpad drivers and update the drivers. that should fix the problem. if the problem continues or if you have no other pc to use insert the operating system cd and re-install the operating system. of course make sure you back up your files first. thank you for using fixya.
May 04, 2009 | Computers & Internet
Vista ultimate doesnot recover from sleep standby and hibernation with freezing of mouse
If you have a USB mouse, try these steps:
  1. Click Start, type device in the Start Search box, and then click Device Manager in the Programs list.
  2. In the User Account Control dialog box, click Continue.
  3. In Device Manager, expand Mice and other pointing devices.
  4. Right-click the USB mouse, and then click Properties.
  5. Click the Power Management tab.
  6. Click to clear the Allow this device to wake the computer check box, and
then click OK.
Vista have some problems with USB mouse and sleepmode and as far as I know there is no real "fix" for it so you just have to make sure it doesn't register the mouse while it's in sleep.
I hope this solves your problem. :)
Apr 05, 2009 | Microsoft Windows Vista Ultimate Edition
Mouse occasionally freezes
thats a laser mouse so its not ur mouse the problem, it is ur internet connection, try not to download anything while playin games online and hopefully it wont freeze that often, hopefully this helps U. :)
Feb 11, 2008 | Logitech MX 400 (931638-0403)
My mouse freezes up
have you tried new batteries?
Sep 15, 2007 | Dell U0636 Mouse
Microsoft MS Windows XP Professional SP2 Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
