Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
VIKING RANGE DOOR LOCK
MANUALLY OPENED DOOR LOCK WITH KNIFE. CANNOT RELEASE LOCK.
  • Tom Hurley May 11, 2010
    What is your model# and serial#. Too what is the age?
5 Suggested Answers
  • 42 Answers
SOURCE: Viking Range oven door does not close properly
sounds like the door hinges need replaced. order a part #PC020009 qty 2
Posted on Dec 21, 2008
Boogan
SOURCE: Viking range self cleaning not working - door locked
This is a more common problem than revealed by Viking.
Heres how I an "amature" fixed it.
Top center of many viking ovens have slots. With a small flashlight look into the center slots. "Its HARD to see" Look for something
shiney thats the latch/hook everything else will be dark.
I used a shish ka bab skwer. You need something like that or maybe an ice pick. Knives screwdrivers and things like that will
damage the face of the oven and then after opeining it you will forever feel bad about marring that very expensive unit.
Take the pick and with the flashlight guide it to the shiney part.
Once touching push to the LEFT. Keep trying as the pick will slip
many times. The latch should have no resistance if you can get on it.
Once open you can try and reset the hook to its open position.
Mine would not reset and prevented the door from closing.
This is now another fix. To keep the hook held to the open position. E mail me for how I jury rigged this part.
Mexvillas@aol.com
I have the hook held open now and will never be able to use the self clean function again. But thats better for me than a open wallet fix for the repair man and then wonder when it will happen again. To repeat. This is a known problem with Viking ovens.
Cheers
Posted on Apr 08, 2009
SOURCE: Viking 36
The door can be removed from the hinge assembly by lifting upwards and outwards while the door is only slightly open - no hardware needs to be removed to get the door off. My door VGIC366 hinges did the same thing a few years ago, and simply cleaning them fixed the problem entirely.
Posted on Jul 30, 2009
housejess
  • 317 Answers
SOURCE: VIKING STOVE DOOR IS LOCKED AND WILL NOT OPEN ,
unplug or turn off breaker to stove for 10 minutes...then try to gently open.....the oven has to be completely cool before it will unlock....when cleaning is done release lock before turning cleaning off
Posted on Nov 28, 2009
Door lock is engaged but door is open. panel says door locked. how do I release lock so door will close?
Hello Maureen, thank you for your post!
I see that your Frigidaire range is currently displaying door lock engaged except the door is open. The best way to release the door lock is to hold down the cancel button for at least ten seconds. If that does not help release the door lock I would suggest disconnecting power from your range for at least ten minutes. We hope that this information is helpful towards the repair of your range. -Matt
Feb 01, 2016 | Frigidaire Kitchen Ranges
Oven door on gas range won't open. Apparently the "clean" cycle was initiated and locked the door and now won't open. Also didn't clean. The range is 4 burner about 25yrs old. I do...
Hello & Welcome to FixYa
This is a common problem that occurs when self-clean cycle is used after a long time or when the oven gets old. Recommended repair is replacing the door latch-lock assembly as the latch mechanism cannot be repaired. Please get back to me if you have any other questions.
Kevin
Jul 18, 2011 | Magic Chef CGR3742 Gas Kitchen Range
My viking oven door has literally fallen off the left hand side hinge - is this a diy FIX?
The door slides onto the two hinges and is held in place with two gravity operated latches. I'm not sure of the condition of your range but it sounds like the door was forced or lifted rapidly allowing the one side to release. The only solution I know of is to remove the other side and reinstall. The hinges have multiple locking positions so the next time you are cleaning your oven, open the door about 8 inches, find the small latches in the door hinge groove, and hold them upwards as you lift the door towards yourself.
The hinges should remain slightly opened. For installation, lower the door onto the hinge posts and pull it outwards slightly.
Oct 27, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
Our dual fuel 36" viking's oven door will not open completely, it appears to be binding
This usually happens if the "Clean" function has been used, then the door is "Locked" for many many hours until it cools down, this mechanism often fails, try disconnecting from mains, trip the "Breaker" leave for 5 mins, and try then.If still no go, i fear you are going to need it serviced.
Mar 15, 2010 | Viking VGSC366-6B Gas Kitchen Range
Oven door still locked after clean cycle
Take off the burner platform over the oven. Slide out the drip platform completely. Remove the access plate over the oven (Use a Phillips head sideways in a locking wrench to loosen screws). Using a long screwdriver slide the locking arm to the left of the oven as you face it, jiggle it a bit and it should release. I hesitate to clean the oven again but at least I now know how to release the lock and I saved $150.00 from my local appliance repair bandit.
Dec 31, 2009 | Viking Kitchen Ranges
VIKING STOVE DOOR IS LOCKED AND WILL NOT OPEN , STOVE WAS IN A SELF CLEANING MODE AND DOOR WON'T OPEN AFTER CYCLE COMPLETE
Nov 28, 2009 | Viking VGSC306-4B Gas Kitchen Range
I have an old(over 20 nyears) free standing magic chef model No. 177-31DB2 range. I put it on the cleaning cycle and everything seemed to be working well. But then it seemed like there was alot of smoke so...
WHEN THE DOOR IS LOCKED ON A SELF-CLEANING RANGE, AND THE TEMP GETS ABOVE 400 DEGREES, IT LOCKS THE LATCHING ASSEMBLY SO YOU CAN'T OPEN THE DOOR AND GET SCORCHED. IF YOU FORCED THE HANDLE TO TRY TO OPEN IT, YOU BENT THE ARM OF THE LATCHING ASSEMBLY. IN ORDER TO RELEASE THE LATCH,
ONLY IF YOU FORCED IT TO THE OPEN POSITION, YOU MUST FORCE IT BACK TO THE LOCK POSITION TO STRAIGHTEN THE ARM.THEN IT MIGHT RELEASE.
IF YOUR RANGE HAS A LOCK BUTTON THAT NEEDS TO BE
PRESSED TO SLIDE THE LATCH TO THE LOCK POSITION,
YOU WILL HAVE TO SET ALL CONTROLS BACK INTO THE CLEAN POSITION AND PRESS THE LOCK BUTTON TO RELEASE THE LOCK ON THE LATCH ASSEMBLY. YOU SHOULD HEAR A BUZZING OR HUMMING SOUND WHEN THE BUTTON IS PRESSED.
Mar 31, 2008 | Kitchen Ranges
Oven cleaning lock
First try to reset the board by turning the range off at the breaker. Let me know what happens so I can help further.
Nov 11, 2007 | Maytag MER6772 Gemini Electric Kitchen...
VDSC365-6B
ove corse you need to make sure your oven is or has cooled down and turn the breaker off for good measure  I had this problem.  I think the locking unit is jumping gears because i hear a grinding sound when Mine locks.  The way I got mine open was,  Lookalong the top of the oven door.  there are vent slits cut in the top, if you look in them where the latch is you will see the hook that is holding the door shut.  I took a butterknife ( you need something flat and strong because of the angle yu have to hold it at.  take the knife and push the hook to the left.  I will take a few tries but it should pop open.  once it is open and power is restored the latch will retract to its normal position.  hope this helps
Jul 19, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
270 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
