Question about Bose (321GS) System
Water was spilt in the face plate of my Bose 3 2 1 system on the right hand side where the display board is located. It wasnt a lot of water but enough for the system to not turn on. Any ideas?
  • 144 Answers
Replace the fuses
Posted on Jul 16, 2010
A CD is stuck in my bose system How do I get it out?
From an other web site
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Oct 09, 2014 | Bose & Wave& Music System
Location of pollen/cabin filter
Audi A4
Part number: 4B0819439C.
Filter element (dust and polen filter) with odor and harmful substances filltration. Placed on the right side of the car, (engine bonnet raised), under cover plate for water box (also for battery box), and under water deflector at the bottom of the windshield - right side for Left Hand Drive (LHD) vehicles:
For Right Hand Drive (RHD) cars the cabin air filter is placed on the left side!
Jul 17, 2011 | Audi A3 Cars & Trucks
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
How do you open the water/ice dispenser dress plate on a Kitchenaid Superba?
Not to be funny, but carefully. There are no screws holding the face plate on. Look on the bottom edge of the plate and you will see 2 slots. That is where the clips are that hold the face place to the fridge. They are molded as part of the plate and just snap off to remove the plate. This may take a lot of force and it is best to work at getting some 'flex' in the left side of the plate, then working your hands down until the snap lets go. Then lift and the plate will come off.
Mar 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
Where is the cabin filter located?
Filter element (dust and polen filter) with odor and harmful substances filltration. Placed on the right side of the car, (engine bonnet raised), under cover plate for water box (also for battery box), and under water deflector at the bottom of the windshield - right side for Left Hand Steering wheel.
!!! For Right Hand Steering wheel cars the cabin air filter is placed on the left side !!!
Nov 02, 2009 | 2004 Audi A4
Top drawer dead bottom drawer funtions fine
1-Pull out the drawer.
2-At the bottom either side has a plastice pin , use a long nose ply to pull them off.
3-The front pannel can be seperated from the tube by put both hands on the side of the front pannel with a pulling out force
Jul 04, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water spilt into top of wave radio cd system and it is dead
Bose radios do not have an integrated fuse link. the water has shorted the main board. the best action here is to, replace the entire unit. this can only be done by sending it in to bose. i understand that this is not the option you wanted but, all replacement boards and internal components are not available for consumer purchase.
This repair or, exchange can only be initiated and completed by the manufacture(bose).
Jun 16, 2009 | Bose Wave Radio
Water damaged 99 Audi A6 Avant
On right hand drive vehicles there is a 'convenience' ECU under the front passenger side carpet (I think it swaps and is under the right hand side in a left hand drive) This ECU operates and controls all the systems you have described, they suffer water damage very easily. This will be the cause of your problems and unfortunately will need to be replaced and coded. The ECU was put in this place to keep it well out of the way of any contamination such as water, then the cars ended up leaking water straight on to it! The carpet in the front can be lifted up from the edge by the door with a few trims removed. You probably had quite a lot of water in there because water runs to the back of the car, by the time its visible in the back a lot of water has entered. Let me know if you want anymore imformation.
Mar 13, 2009 | 1999 Audi A6
My Frigidaire refrigerator water dispenser leaks water inside the door, the water runs down the front of the door from the bottom of the front panel. How do I remove the panel to repair or replace the...
lift up & out on the drip tray (it will come out) after removing it you will see 3 screw. unscrew the screws & lift the face plate of the despenser & it will come off. Be careful though. There is a ribbon wire connected to the back of the face plate. make sure to dissconect the ribbon wire from the control board not the back of the face plate (its alot harder to reconnect to the face plate & pretty simle to reconnect to the control board).
May 11, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice doesn't dispense and both freezer and refrigerator aren't cold enough
yes. pull out the frig and look on the back. facing the back on thr right hand side there a rectangle metal plate. under that plate is the main computer board that controls the whole thing. they have been causing alot of problems one of which is the one your having. replace that board and your problem is solved
Nov 26, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Bose (321GS) System Logo
80 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
