Question about Kitchen Ranges
Bagless 2000 has a very weak suction although the motor is running. Cleaning the filters did not help. Removing the filters did not help.
  • Kitchen Ranges Master
  • 6,826 Answers
How many filters did you remove?
Some filters on vacuum cleaners are hidden down near the motor in upright vacuum cleaners.
The HEPA filter might be clogged and needs cleaning.
Actually, I am not sure if your Bagless 2000 is a vacuum cleaner or it is a Kitchen Range,as your title says 'Kitchen Ranges.'
Please clarify.
Posted on Jul 15, 2010
Very little suction at beater brush.
Hey, this is Leland with Crucial Vacuum,
If the brush bar is not working properly there may be several reasons.
Firstly, the motor may be the problem. If you hear any noises while the machine is running, you should contact the original manufacturer for trouble shootingsolutions.
Secondly, your vacuum may be in need of new parts. By changing either the brushroll or belts, you should be able to increase the quality of the suction.
You can purchase replacement parts for the DC17 direct from Crucial Vacuum with freeshipping and an exclusive 10%coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=dc17
Feb 11, 2016 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum cleaner stops
The motor has a thermal reset built in. If the filters need replaced the motor can overheat. Filters should be replaced frequently to insure proper cleaning suction and motor life
Jan 04, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Weak suction
if you've changed filters and checked for blockages it may need a new suction fan ,,you can download the diagram off the link below
http://www.ereplacementparts.com/black-and-decker-phv1800-dustbuster-parts-c-4167_8887_8897.html
Mar 13, 2013 | Black & Decker PHV1810 Bagless Handheld...
Can anyone help with an older Euro Pro EP055, It has very little suction.
Cleaning filters on a bagless vacuum helps but filters should be replaced frequently, as often as every 3 to 6 months on some vacuums. Foam filters aren't as critical to replace because the pores are very large (which also means they don't filter out the small particles) so they don't clog as easily but paper filters have much tighter pores which become clogged and restrict the airflow. Cleaning paper style filters with water which can pack the fine dust into the pores clogging the airflow even more.
I recommend replacing filters st least onceor twice per year and cleaning them after each use for best performance and longer vacuum life. Blowing the dust out with an air compressor is my preferred method.
Changing filters frequently on a bagged vacuum isn't as critical because the bag collects most of the fine dust, dirt and gunk. The surface area of a bag is much greater than that of a filter so a bag is less likely to get clogged than a filter. Most homeowners change the bag once per month which keeps the air flowing smoothly.
Sep 30, 2017 | Euro-Pro EP055 Bagged Canister Vacuum
No suction. dirt goes into the filter instead of the canister
Check the motor and clean it properly. A very dirt motor will cause no suction or weak suction.
Be sure the motor is running on proper speed, a weak motor will cause a weak suction.
Thanks for asking.
Jun 25, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
No suction
OK - Details details details.....
If the motor turns on and only sucks a little bit or you are experiencing a great loss of suction,.
THEN
You have a plug somewhere
Be it a partial block from say a HEPA Filter
or else it is a block in the path of travel where items get sucked up into your vacume.
If you look back to the last time someone used it, was it a fine powder which was cleaned up? then look to the filter (see owners manual for maintenance and or cleaning of the vacume machine) Otherwise is it possible that someone else used it and get it clogged with something larger? Although I'm thinking it is the HEPA filter needing cleaning...
The good news is that if the machine turns on, then you know you have a block somewhere in it, bottom line is you will need to find the clog and you'll be back up and running in no time.
Best regards
Ck
Jan 05, 2011 | Hoover Elite Rewind Bagless Upright...
Power head turns on and works the power that turns vacum on not
If the suction motor doesn't come on but the brush motor does, you have a bad vac motor. If neither motor runs, it's probably a cord problem. Most parts for these are not available anymore.
Apr 30, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
No suction up into the canister
Try cleaning the Hepa filter and the rear filter behind the motor
May 17, 2009 | Bissell CleanView II Plus Upright Bagless...
Bissel model 3594 has weak suction
clean the filter abovethe dust cup... and any other filters
Feb 16, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Hoover Light on
ALTHOUGH MOST FILTERS SAY WASHABLE THEY DO STILL NEED TO BE REPLACE AS WASHING THEM SHRINKS THE FILTER AND EVENTUALLY CLOSES THE AIRWAYS. WHICH ALSO IF NOT REPLACE WILL OVER HEAT MOTOR IN MACHINE AND CAUSE MOTOR FAILURE.
Mar 27, 2008 | Vacuums
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
