Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Screen went black tv dead power light blinking unplugged and replugged neither direct power or remote is working - power light continues to blink rapidly - sony xbr-5 40 inch purchased in 2008
  • 1 more comment
  • ludvanb Jul 15, 2010
    How do I do this? and how do I avoid it in the future?!!!
    ok - but how do i order parts and get it installed? can i be sure it is the power supply?
    How do I get the number off the part board and then get someone to install it?
  • 4,889 Answers
That us definitely a power supply failure. Probably some kind of surge has knocked out the power supply. We can try a component level repair but the easiest way will be to replace the power supply board. Should cost you around 100-150 bucks.
Posted on Jul 15, 2010
  • 4 more comments
    Do you still think that if it came back on and went back off? Came back on again? When it goes off the power light blinks... if so, what is cheapest way to deal with?
    Interestingly enough - we just replugged and rearranged the power supply to a surge protector last night - was plugged directly into the wall before????
  • eagle338
    eagle338 Jul 15, 2010
    Yes. I think its a case of knocked out caps that are not able to hold the charge. We can attempt a component level repair if and only if you can follow a schematic and use a meter. That would be the cheapest way.
  • eagle338
    By meter I meant multi meter. Its a device that measures various values such as current, voltage, capacitance etc., That is how we test circuits. Note that this may be risky for you as it seems like you have not worked on electronics before. To avoid this in future always use a surge protector, preferably one that employs a fast acting pico fuse.
  • eagle338
    Yes I am sure its the power supply. If you can get me the part number off the board I can find you a replacement.
  • eagle338
    Unplug the set, remove the back cover and take a look at the board without touching anything. There should be a serial number and a part number. Get me both and I will find you a replacement. As for getting someone to replace it, use our repair directory to find a tech in your area.
    http://www.fixya.com/repair
Sharp flat screen - TV went black- now just blinking light - when pressing on/off button blinking light won't stop
fault condition light ,
unplug replug power
if still then its detecting a circuit fault you cant fix easy.
Jul 25, 2014 | Televison & Video
Red light blinks 4 times, no video or audio
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Apr 27, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
TV was working when the screen went blank and the red light on the front began to blink.. I have tried several options of plugging it into different locations. No luck.
Try tv unplug,replug it back about an hour later.Let the tv reset itself back to factory setting.The tv should work now.Not than,the power supply board is dead.The power supply board,that the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 06, 2010 | Akai Televison & Video
My Toshiba 50H81 screen black, no sound & power light blinking
sounds as if your power supply needs to be repaired. the capacitors over heat and crown or leak.
Jan 01, 2010 | Toshiba 50H81 50" Rear Projection...
Black screen and no sound on TV
what is the brand, model? try to be specific if you want be helped!!!
Sep 11, 2009 | Televison & Video
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Jun 02, 2008 | Televison & Video
Sony 62" Power TV Problem
Is your model KP61HS10? If so I can help you?
Jan 13, 2008 | Sony KP-61HS10 61" Rear Projection...
HP FLAT SCREEN TV BLINKING POWER LIGHT/BLACK SCREEN
sounds like the power supply has gone bad.
Jan 04, 2008 | Computers & Internet
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb, www.bluestar-online.com
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
137 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
