Routers
Problem for Routers
Generic problem for all Routers
Setting up my 4 ports 11g wireless ads...
By fabsab on Apr 20, 2008
When I go into the IP address 192.168.1.1 (given in the manual) it does not recognise the default username and password given in the manual ("Admin").
Comments:
Apr 21, 2008
- Strangely we have tried the two things quoted by you but it has not worked.
Same Problem
Jan 01, 2009
-   I have a Problem with setting up my 11g wireless router. please help!.!.!
i can't get bitTorrent 6.1.2 to work properly it says that my router wont let it through on such a port ive gone into router settings (192.168.1.1) but cant figure out what to do! please help... -   GForce69
Nov 14, 2008
-   hi i got a new wireless box but its not working at all i got no idear wats wrong with it i put it to the phone and can find it but says default????? -   coyne_mc
Solution #1
posted on Apr 21, 2008
Somewhat Helpful)
viaujoc
Rank: Guru
Rating: 86%, 107 votes
1. Make sure to use the exact upper/lower case as stated in the manual. The password is usually case sensitive but the username may be either, depending on the vendor's implementation. In doubt, make sure they are identical as in the manual.
2. You may have received a router with a pre-existing configuration. Look for the "Factory reset" feature in your manual. Once the reset is done, you should be able to connect using the default username and password.
Comments:
Apr 21, 2008
- What is the exact brand and model of your router?
Apr 21, 2008
- Since I don't know much about your network setup, I am assuming nothing. Please try this:
1. Disconnect the power cord from your router
2. Open a command prompt on your PC (Start->Run, type "CMD")
3. Type PING 192.168.1.1
Do you get "Reply from..." or "Time out..."?
If you get "Reply from..." it means that your have another device on your network that is already using the IP address 192.168.1.1. So, it also means than you were hitting this other device instead of the router you are talking about here.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
I lost the Belkin F5D9230-4 Wireless G Plus MIMO Router Installation CD. Where can I find the... (More)
Answer
how do you Security enable the wireless router
Answer
ps3 wont conect to friends on maden 10 is wired derect to the modem and still reading nat 3 what do... (More)
Answer
we switched providers and not the router won't work
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 1357
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
