Question about Hayward SAND FILTER, PRO SERIES
Recirculating a hayward sand filter for inground poola
Do i have to open the valve to waste when i just want to recirculate
  • 8,404 Answers
No ... waste dumps the water ... recirculate recirculates but does not filter ... filter filters the water ...
Posted on Aug 04, 2010
How does Hayward Sand filter work
Excellent answer Robco, One slight variation of an explanation about "waste"... When in this mode, water never actually enters the filter tank, it goes in the valve from the pump, and out of the valve through the waste port.
Very similar to the "recirculate" mode, it comes from the pool with the help of the pump into the filter valve, and right back out the filter valve, without ever going into the tank, and back to the pool via the return port.
Jun 29, 2014 | Hayward SAND FILTER, PRO SERIES
Vista pro 711 blows water out waist on filter setting what am i doing wrong
Hi. Have you disassembled the multiport valve recently? If so, then the diverter and or handle was improperly aligned.
If all other functions work as they should (waste, backwash, recirculate,rinse or closed then there is an issue with a worn diverter (or spider gasket) or the diverter valve stem is hanging up slightly. valve top would need to be disassembled and lubed.
hope this helps.
Jun 18, 2014 | Hayward SAND FILTER, PRO SERIES
I cannot read the diagram on top of my hayward sand tank filter pro-series s244t filter,close,waste which way
go to westport pools.com and see if you can find a picture of it or go to hayward filters..
Jan 06, 2014 | Hayward SAND FILTER, PRO SERIES
Hayward sand filter
Reference your pressure gauge as the 12:00 position. Going clockwise-
12:00 is Filter, normal running position
2:00 is Waste, water goes from pool and exits the waste line, bypassing filter.
4:00 is Closed, used only when servicing equipment
6:00 is Backwash, reverses water through the filter and goes out the waste line.
8:00 is Recirculate, water bypasses filter and returns to pool.
10:00 is Rinse, water goes through filter and exits to waste line, used briefly after backwashing to clear sediment from filter.
Note that the "pointer," not the handle that you grab, indicates which setting you are on.
May 19, 2013 | Pool & Spa
I have a Dream Line sand pump and label on top fell off. Can not tell where to set valve for backwash, rinse,waste or recirculate are? thank you for your time and help.
Filter position is with notch on handle seated and pointing to the pressure gauge.
Working clockwise - Waste; closed; backwash; recirculate; rinse;
May 05, 2013 | Hayward SAND FILTER, PRO SERIES
Was wondering how to change the settings on filter. Its a Hayward Pro Series High Rate Sand Filter and the instruction manual says it have about 5 different ones....i.e. waste, recirculate, but we were...
If you know how to place the valve into the backwash and filter positions you need to use these. The others are important at times but they are not as important. In fact another type of backwash valve has only two positions. This valve is one of the most popular valves for this function so it must not be too bad. I hope this helps.
Aug 20, 2011 | Hayward SAND FILTER, PRO SERIES
When vacuuming my pool, the dirt, etc. is not filtered out and just recirculates into the pool
Normally, you set your pool filters setting to "filter" when you vacuum. Is this the setting you are using? If that doesn't seem to be working or your pool is especially dirty, change the valve to "waste" and operate with the cleaner on that setting. That will bypass your filter entirely. If this works, it could be that your filter is dirty and needs to be backwashed or have the sand changed.
Jul 10, 2011 | Hayward SAND FILTER, PRO SERIES
Water is leaking out my waste line when using recirculate.
Replace the internal "wagon-wheel" looking gasket inside the valve. Its job is to keep the water going thru the valve and ports the handle is set to and not leak out of the waste port.
Aug 08, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
224 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
