Question about RTO PasLode 900420 Impulse Framing Nailer
How to ajust the nail depth - RTO PasLode 900420 Impulse Framing Nailer
  • 2,176 Answers
If you have a newer framing nailer you need to lift up on the mechanism on the front of the tool and then move the lower portion of the safety. REMOVE BATTERY FIRST!!! If this is an older one you will find just 2 screws that must be loosened and then move the lower portion of the safety. ALWAYS REMOVE THE BATTERY OR THE FUEL CELL BEFORE MAKING ADJUSTMENTS.
Posted on Jul 19, 2010
Nr90ae how to ajust nails
How do you mean "how to ajust nails"? do you mean the depth that they're into the timber>
Sep 06, 2014 | Tools & Hardware - Others
Bostich RN-46 seems to be over sinking the nails even went set to low depth
Adjust the air pressure on the regulator to about 90 lbs. or lower. maybe higher than 90 but that should help you set the depth.
Jun 05, 2014 | Stanley Factory Reconditioned Bostitch...
How do i control the depth the nail shoots in a bostitch coil nailer
The bostitch nailer pictured along along with your question is a RN46 roofing coil nailer. It has a dial on the front of the nose for adjusting depth. Some older nailers (roofing nailers) do no have a means of adjusting so were set at the factory for best performance. The question of depth usually comes up when lower bumper fails and the nail is driven too deep. Easy test. Remove nails and find a very soft piece of wood. Dry fire the gun against soft wood and measure how deep the driver is entering the wood. Harder test. Remove the head and use any handy tool to push driver down to bottom. Measure how far the driver extends past nose (should be about 1/8 to 3/16). If more, replace the lower bumper. Good luck
Jun 21, 2012 | Stanley Bostitch Nail Gun
My bostitch nailer depth is setting nails to deep at it's lowest setting. Can this be ajusted
You didn't specify what model but what I would look at is the safety/work contact for being bent and also the air pressure that you are using, The recommended air pressure is between 90 and 110 PSI. If you give me the model number I will check further.
Feb 21, 2011 | Bosch Air Tools & Compressors
I have been installing a treated pine deck, but the nails are been driven in to far, i have tried adjusting the pressure from the compressor but have had no luck is there a depth adjustment on the gun?
Yes, there is a depth adjustment. Most of the Bostitch models have a push button on the left side near where the nails come out. With the air unplugged, push in this button and you can slide the head assembly up or down to make your adjustment. Slide it out for less depth. It sounds like maybe yours is fully seated, providing the maximum depth.
Dec 13, 2010 | Stanley Bostitch Coil Framing Nailer
How do I adjust the depth of the brad nail on the porter cable BN 125A brad nailer
Hello. To adjust the depth of the nail you have to increase or decrease the air pressure from the compressor. Look at the compressor and you will see a knob or dial that you can turn to increase or decrease the air pressure. Do this adjustment in small increments testing the nailer by driving nails into a scrap of the same material you will be driving the nails into on the actual job. Increasing the pressure will drive the nail deeper and decreasing the pressure will drive the nail less deep. Joe
Nov 10, 2010 | Porter Cable Cable BN125A Factory -...
I have a RN45B roof nail gun that wont sink the nails all the way. How do I adjust depth of nails?
The adjustment is inside the magazine there are 3 setting depending on the length of nail. Here is a PDF of the owners manual for that tool, the procedure to set the depth is on page 6. http://www.bostitch.com/catalog_images/web_pdf/103280.pdf
If after setting the depth you are still having issues you can adjust the pressure on your compressor. The operating pressure for that unit is 70 - 100 psi. Do not exceed 100 psi and remember to disconnect your hose before loading/unloading or making adjustments to your nailer.
Oct 10, 2010 | Garden
I have dewalt dc618, nail doesn't goes all the way in, please help?
Below find information on how to adjust for depth, however if you have already made adjustment then check for broken tip on driver blade. The blade is not expensive and available from dewalt service center.
Please note the following from manual:
Adjusting Depth
The depth that the fastener is driven can be adjusted using
the depth adjustment wheel (C) on the side of the tool.
WARNING: To reduce risk of serious injury from
accidental actuation when attempting to adjust depth,
ALWAYS:
• Remove battery pack.
• Engage contact trip lock-off.
• Avoid contact with trigger during adjustments.
1. To drive the nail shallower, rotate the depth adjustment
wheel (C). There are twelve depth settings, 1 being the
shallowest and 6 being the deepest.
2. To sink a nail deeper, rotate the depth adjustment
wheel (C) to a higher setting.
Sep 08, 2010 | Dewalt DC618KA Angled Nailer Kit
Nails won't set
The Bostitch should have a one-touch depth-mechanism with seven settings. You should make the required adustment(s) to this mechanism to alter the nail depth.
Note: While it is at first glance easy to use, after switching the settings a number of times it may become apparent that the coarse settings lack the refinement necessary for smooth and detailed adjustment.
Jan 14, 2009 | Stanley Bostitch N88rh Framing Nailer...
RTO PasLode 900420 Impulse Framing Nailer  Logo
149 people viewed this question
Top RTO Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Jim Goldsmith
Jim Goldsmith
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
