Question about Toshiba Electronics - Others
I have a transistor inverter tosvert vf-sx and i need help finding the manual download
2 Suggested Answers
SOURCE: We need manual for toshiba tosvert-130G3 inverter.
Toshiba website has PDF manual online.
Posted on Jan 18, 2011
11Kw pioneer VF-5000 inverter
please send me the user manual for vf-5000(11Kw)?
Jun 23, 2014 | Black & Decker Vector Cable Kit for 1200...
OH error in toshiba inverter VF S11
Follows are the part of the manual
Possible causes
• The cooling fan does not rotate.
• The ambient temperature is too high.
• The vent is blocked up.
• A heat generating device is installed close to the inverter.
• The thermistor in the unit is broken.
Remedies
Restart the operation by resetting the
inverter after it has cooled down enough.
• The fan requires replacement if it does
not rotate during operation.
• Secure sufficient space around the
inverter.
• Do not place any heat generating device
near the inverter..
May 03, 2014 | Toshiba Electronics - Others
Control will not run motor
Power is present where circuit board is at, but motor does not run.
Nov 06, 2013 | Toshiba Tosvert 130g2 Transistor Inverter
Toshiba Transistor 130G2 OCA error
Basically it is telling you that the inverter is bad. You can disconnect the output so there is only the power going to the inverter and see if it will come on with a no load situation but if it still fails, there is no fix other than to send it back to manufacturer.
Try this as your one and only "maybe":
Reset is press CLR and WRT at same time (I think).
Page 7-7 and 7-8
http://www.toshiba.com/ind/data/tag_files/G2%20Manual_559.pdf
Oct 25, 2012 | Toshiba Tosvert 130g2 Transistor Inverter
I turn the power on push the ctrl button and push start, The unit turns on ready to start but does not start
Try reset first, If that does not resolve it, suspect the start switch as the culprit. You might be able to clean the contact surfaces with contact cleaner and rapid cycling of the switch.
Dec 28, 2011 | Toshiba Tosvert 130g2 Transistor Inverter
When run comand is enable I get an error OC1. I disconnected the load and still get the same error. The inverter has been working fine for the last three years
Overcurrent on acceleration is what the code is supposed to be. There may be a capacitor failing in the finals of the output stage, or a resistor has shifted value..
Sep 04, 2011 | Toshiba Tosvert 130g2 Transistor Inverter
How can i troubleshoot a transistor?
A transistor is a switching device. You can connect it with a bulb using wires and a power suppy along. You also need to be more specific as to what type of transitor do u have. as most of them have different characteristics.
May 13, 2010 | Toshiba Tosvert 130g2 Transistor Inverter
Electronics - Others Logo
303 people viewed this question
Top Toshiba Electronics - Others Experts
frankdanfelt
ray gallant
Da Doc
Are you a Toshiba Electronics - Other Expert? Answer questions, earn points and help others
