Question about Snap Sights SS01 Film Camera
Batteries how do i put batteries on my snap sights cam? does it even need any?
    Problem Solver:
  • 17 Answers
No it doesnt
Posted on Jul 15, 2010
Good day i need advice on what to do. my cams are running dry but the oil light is not showing me a signal of it its still off. i think it could be running dry because my cambelt has snapped twice after...
"my cambelt has snapped twice"
doom.
if you keep snapping belts, the engine is toast.
at the least the head is wrecked.
you skipped the 60k service points, so now must pay the gods
of physics. (he is called the cruel god of entropy) "sorry !"
the cam belts do not last the LIFEof any engine., not even close.
time to go to mr, goodwrench , any ASE mechanic will tell you the truth. any.
Oct 26, 2013 | Honda Cars & Trucks
Had not used our mouse in quite awhile, put in new battery but still is not working
If its the 3000 ... you need to snap the battery compartment in correctly to get the battery to work.
Replace the battery. When you reclose the battery compartment you just snap it in place but be carefull.. even though its easier to insert the top and then slide the bottom down in DO THE REVERSE... insert the bottom prong allllll the way in and then snap the top forward and into pace. In order for the battery to work the top needs to be firmly in place and I've found that snapping it in in the aforementioned way is the only way to make sure its snug n stuff.
Hope that helps. I've had this mouse for five years and love it but alllways forget that issue in replacing the battery and inevitably spend fifteen minutes scratchin ma head everytime the battery needs replacement.
Feb 25, 2010 | Microsoft Wireless Notebook Optical Mouse...
My webcam stopped working all of a sudden. i used to yesterday and now it wont even open. what do i do?
Webcams are flaky, esp when using yahoo. Off the top of my head, I dont recall if your pc has a built in internal cam. A good thing to try is simply rebooting the PC and restarting the webcam. If that doesnt help, check the cam manufacturers site to see if the driver needs to be updated. Lastly, it might not be the cam after all. It could be the program that's using the cam, such as yahoo or MSN or whoever. Restart the machine first (thats likely gonna fix it), but if it still fails, try using the windows camera scanner option to snap a pic. If you can snap a pic, the hardware is ok, and you have a software issue. If however you try all of these things and still have failure, then you could have a bad USB cord (external cam) or a bad camera cable (internal built in cam). If you are under warranty, call Dell to have a tec sent out to replace your internal cam.
Nov 11, 2009 | Dell Studio 15 Laptop
Can I purchase a replacement battery cover (snap lid) for a S5700/s700 fujifilm digital camera
Check out e-bay and request exact part you need for exact model. Put a "search for" on it, somebody will get back to you. I seen lots of battery doors listed for several makes and models on someones sight when I was looking for a Kodak cable!
Oct 31, 2009 | Cameras
Snap Shot Pixtreme 3.1 M camera corrupts SD cards
If you just put the card straight into the card reader, not forgetting to set write-protect, you should eliminate this problem.
Aug 04, 2017 | Snap Sights SS 1.3 Digital Camera
Mpeg4
I have a optimus and can not find the manuel, could you please let me know how to work the camera and cam
Apr 26, 2008 | Panasonic SVAV100 D-Snap MPEG4 Digital...
Sight target needs adjustment
I also had the same problem my Yardage Pro Compact 600. We live in the desert and I often leave my golf bag in the trunk of the car. One day the display on the rangefinder was shifted up so I assumed that the heat affected something. After checking with Bushnell, their answer was to ship it in and couldn't guarantee a cost.
So I also peeled back the rubber grips from the bottom - you only need to go far enough to unscrew the four screws. From there you have to snap apart the case so the top shell comes off (be sure to remove the battery and cover first). Once you've done that, unscrew the top circuit board (mine only had 2 of the 4 screws from the factory). Be careful not to unplug any of the 3 ribbon cables.
Move the top circuit board aside. Looking from the top front, there is an assembly at the back that holds the laser/reader, it is held in by 3 screws, 2 on the back left and 1 on the back right - remove them. Carefully remove the assembly leaving the 2 ribbon cables in tact. The 3rd (largest) ribbon cable is taped to the center sighting barrel. Gently remove the tape, the ribbon cable disappears into a **** in the back of the sighting barrel near the eyepiece, it is connected to the LCD display. Now flip the unit around and looking from the back eyepiece, remove the 2 screws near the ribbon cable. Now you should be able to lift the eyepiece up and away from the sighting barrel.
The ribbon cable and LCD window at the end of the cable should be glued on two corners inside the eyepiece (worse case the LCD is loose as mine was because the glue had deteriorated). First scrap out the old glue from the LCD and eyepiece frame, being careful to not let the remnants drop inside the eyepiece or you will see these in the viewfinder once you get it back together!
Using thick superglue and being careful not to touch the LCD and leave a smudge (or forget how it came out as your yardage display will be backwards!), put a tiny drop of glue on each lower corner of the eyepiece frame. Now carefully position the LCD window and push down to the bottom of the eyepiece frame. Try to center it left to right as near as possible (mine had a little gap on each side) while holding the LCD against the bottom edge. Keep it there until the glue dries.
Now reassemble everything, making sure the sighting barrel and especially the laser/reader assembly fits snugly in its cradle before reinstalling the 3 screws, then install the top circuit board. Snap the top cover back on and before putting the 4 cover screws in, put in the battery/cover and test it. Remember if your display is reversed you installed the LCD backwards!
Jun 23, 2007 | Bushnell Yardage Pro 600 Rangefinder
Display blurred and cam showing low batt
Bad luck is that the CCD sensor in your camera has stopped working properly and needs replacing. You are lucky though because Canon repairs this fault on S1 - IS free of charge so phone them and inquire.
Dec 26, 2006 | Canon PowerShot S1 IS Digital Camera
Snap Sights SS01 Film Camera Logo
49 people viewed this question
Top Snap Sights Photography Experts
Tony
Are you a Snap Sights Photography Expert? Answer questions, earn points and help others
