Question about Frigidaire Compact Air Conditioner
Window air conditioner cools but doesn't dehumidify room. This has been the case since it was new. The unit is tilted down slightly in back as recommended. The room is small. I read that having a unit that is oversized for the room can cause this problem.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
  • blueextc3221
    blueextc3221 Sep 05, 2010
    Normally, 1 thumb ratings are reserved for abusive posts. I don't see what in my answer to you is abusive.
    If you are still having issues with your A/C unit - remove it from the housing. The INNER condenser coil is likely dirty. This rarely gets cleaned - and is responsible for removing the humidity.
    If the air does not pass over the fins - the humidity can't be removed.
    I have indicated the side of the coil you need to concentrate on with red arrows.
    Thanks for using FixYa - please think about changing the rating you gave this answer - as we do this for free, and ratings are our only satisfaction.
    Thanks!!
I have a heat and cold comfort aire window unit it blows well but the air is not cold just cool
call an air conditioning repairman sounds like it needs a little recharge and sadly we can not do those ourselves
Jul 23, 2015 | Heat Controller Comfortaire REG-253J 25000...
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    My frigidaire air conditioner LRA067AT7 won't cool
    The thermostat isn't turning on the compressor. Check it out first. If it seems ok then check the wires going to the compressor. One of the 2 places will be the trouble .
    Feb 05, 2014 | Frigidaire 6000 BTU Window Room Air...
    WINDOW AIR HAS A DEHUMIDIFY ON IT. IF THAT SETTING IS ON, WILL IT COOL THE ROOM OR JUST TAKE OUT HUMIDITY?
    Just take the humidity out. Even if you could operate both modes at the same time, the AC side would struggle, because dehumidify mode generates heat.
    Hope this helps you and thanks for choosing FixYa.
    Jul 31, 2011 | Heating & Cooling
    Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
    Here is a tip about troubleshooting your air conditioner...
    There are many things that can cause your air conditioner not to cool...
    AirConditioner Trouble - Review the Possibilities
    heatman101
    Jul 24, 2011 | Danby DAC5020 Air Conditioner
    Is the dry mode on the airconditioner a dehumidifier
    Air conditioners and dehumidifiers both work on the same idea. A dehumidifier is a "air conditioner" that doesn't run so good as a air conditioner, plus, it sits on the floor in your basement (where ever) and not in the window.
    The idea is to draw warmer air (which holds more moisture) into the machine where it is chilled (cooler air can not hold as much moisture). The moisture is deposited on the coils and it drips either to a drip pan (where it runs out the back to the outside (AC)) or a catch bucket (in a dehumidifier and you either dump it in the drain or you have connected a hose and led it to the drain). The air that is returned to the room contains less moisture than it did when it entered the device. The best relative humidity is about 50%, BTW. Not to wet and not to dry.
    The goal in the case of a AC is cool air (which contains less moisture) and the goal in a dehumidifier is less humidity (moisture), but not necessarily cooler air.
    I am not familiar with "dry mode" to which you refer. You have mentioned your device is a Goldstar Microwave Oven so it is impossible for me to gather any information on your particular model AC or dehumidifier.
    I hope this information has helped you today. Thank you for your interst in FixYa.com. Please make a favorable evaluation of this response.
    Jul 18, 2011 | Goldstar Microwave Ovens
    My window is only 18-19" wide. I need to know the
    You can find the information you're looking for, as well as the Owner's Manual and Installation Guide at the following link.
    http://www.frigidaire.com/products/air-conditioners-dehumidifiers/window-air-conditioners/fra052xt7
    Hope this helped you.
    Jul 14, 2011 | Frigidaire FAX052P7 Compact Room Air...
    Why does the manual say not to put the air duct to the window when in the dry mode (dehumidifier)?
    When you put the duct into the window you are sending the heat outside causing the unit to cool the house. When you run in the dry mode you need the heat to come back into the room keeping the room the same temp. This is how normal dehumidifiers work.
    Oct 23, 2009 | Heating & Cooling
    Danby dpac7008 portable air conditioner
    I want to know how these portable air conditioners are supposed to be set up. Do they have to be on the same as the window out of which the hose goes? If the window is 4.5 feet off the ground, does the air conditioning unit need to be put on a table to make it and the window on the same level?
    To the best of my knowledge the unit can stay on the floor and included the product features listed below and it does have a dehumidifier reservoir with direct drain and to make sure if you use the drain hose that the hose is higher than the item that you are draining the water into or you can elevate the unit so that the hose can drain outside and out the window - but you can also drain the water into a bucket or some thing that will hold water. I hope this will help you…..
    Product Features
    picexporterror From our expanded online assortment; not available in all Best Buy stores
    picexporterror 7,000-BTU cooling capacity lets you cool rooms up to 250 sq. ft.
    picexporterror Electronic temperature controls let you adjust the temperature in 1° increments for precision cooling; 3 fan speeds
    picexporterror Dehumidifier mode removes up to 45 pints of moisture in up to 24 hours; 6.3-pint dehumidifier reservoir with direct drain
    picexporterror Auto on and auto off timer
    picexporterror Overload protection helps protect the air conditioner from power drains and surges
    picexporterror Mesh filter is removable for quick and easy cleaning
    picexporterror Includes remote
    Apr 06, 2008 | Danby DPAC9030 Air Conditioner
    Frigidaire Compact Air Conditioner Logo
    174 people viewed this question
    Top Frigidaire Heating & Cooling Experts
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Bill Long
    Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
