Question about Google Chrome
How do I get a recently purchased used chrome shelf to look like new. It looks to have some rough bumpy spots and discoloring? thanks.
  • 4,806 Answers
I take it you couldn't find a metal header on this site?
You can purchase chrome cleaner from any hardware or car accessories store which should bring the shelf up like new. It's a bit like the process of waxing a car and you will be surprised with the results.
It may not get rid of all the bumps but it should provide a mirror finish if you use the chrome cleaner as per the instructions. Chrome cleaner is not expensive at all and should have plenty left when you're done.
Regards.
Posted on Jul 15, 2010
Harley-Davidson exhaust pipes too hot(low rider 2016 s).
Hi, Lamont some brands of motorcycles will have exhaust discoloration right out of the gate when brand new due to engine design and the quality of the chrome plating. These bikes will also have chrome heat shields to prevent burns from accidental contact and hide ugly exhaust discoloration. Some manufacturers go as far as having heat shields on mufflers. If you purchased a brand new set of chrome aftermarket mufflers or a complete exhaust system only to find excessive bluing on the headers and golden and sometimes blue areas on the mufflers appear after a few hundred or so miles of riding your first impression is your exhaust is running too hot which must mean so is your engine. Wrong! exhaust discolour is caused by 3 different things.
1. Poor quality chrome plating, usually dictated by the price of the part.
2. Retarded ignition or cam timing caused by improper installation or a faulty CPS, CKP, MAF, MAP sensor.
3. Mufflers discoloration is caused by an excessively rich fuel condition.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Jun 21, 2016 | Motorcycles
I heard something snap and then noticed that the rear of the car drives very bumpy
Can you provide more info? Did you hit a bump? What do you mean by 'drives bumpy?' Does it ride rough, or does it go up and down a lot after you hit a bump, or something else? Can you further describe the snap you heard, and what was going on when you heard it and immediately afterward (e.g., driving 40 mph on a paved road, hit a pot hole, heard a loud 'breaking' sound as if something snapped/broke, and the ride of the car seemed to immediately change to being more harsh/rough)? Have you had any work done recently, such as tires changed or rotated, struts replaced, wheel alignment, or brakes replaced? Did anything else change (e.g., now when you hit a bump, you hear a new noise in the rear)? Were you carrying anything heavy in the trunk or back seat? I had a '99 Corolla for several years, and had zero problems other than a worn out driver's door handle and a couple of cracked windshields. Great car choice!
Jul 18, 2014 | 2000 Toyota Corolla
Discoloration on ceramic top
Hi- High temps make for tricky maintenance of glass or ceramic tops. The heat element must pass its heat energy through the glass or ceramic and into the pan. Water droplets will steam away, while a spatter of oil or even a few grains of sugar will melt and burn to a tough film of carbon on the surface. The obvious preventitive measures of checking pan bottoms thoroughly before contact with clean (yes- very clean) cooktop surface mean most spots may be small, they can be annoying to look at and tough to remove. My best cleaning results for these spots came from using a VERY small amount of OVEN cleaner (use gloves) on a paper towel placed on spot for a few minutes. A clean, new razor blade may be used to scrape off film. Hope this helps. - Thanks- ED
Feb 25, 2010 | Kitchen Ranges
Bubble-like spots on lcd
Your Licquid Crystal Display appears to have gone bad... much like a dead pixel in a TV, you get a dead spot on the display of your lcd that looks like a bubbe.
You need to have the screen replaced or you will have to live with the bubbles. If the PC is still under warranty I'd send it in for repair. You may be able to pick up an inexpensive replacement on eBay, but make sure you are careful if you replace the screen yourself.
Apr 27, 2008 | Acer TravelMate 4150LCi Notebook
Screen Discoloration Problem
dJbsharp1: Check if the cleaner you use discolor or remove the clear of the screen. Touch the cleaned part and somewhere else on the screen to see if is rougher than the part you didn't clean-up. If this did not occur you can clean it up completely and watch the difference. If it's rough as I described you, a replacement will be necessary. It is easy to replace. Very easy. Part Number: 23430829 https://www.vancebaldwin.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=4003246&smodel=56H80 Click below to all the info and also for instructions on how to do-it-yourself with the service manual for FREE!!! Good Luck !!! https://www.vancebaldwin.com/shop/research_new/TBA/56H80.pdf SithPitt
Jul 04, 2007 | Toshiba 56H80 56" Rear Projection...
CD door won't open
New CDs may have some rough spots around the inner and outer edges. If such a CD is used, this unit may reject the CD. To remove these rough spots, rub the edges with a pencil or ball-point pen, etc.
Dec 31, 2005 | Jensen JCR-280 Shelf System
Cds will not open
Dec 26, 2005 | Panasonic SC-PM31 Shelf System
The 5- empty CD trays do not open
Dec 21, 2005 | Panasonic SC-AK25 Shelf System
CD doors will not open
Dec 20, 2005 | Panasonic SC-AK25 Shelf System
Google Chrome Logo
53 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
