Question about Williams 3003622 Ceramic Wall Mounted Panel Heater
Heater still lets out heat
Its summer and the heater still lets out heat how do i turn off the pilot?
    President:
  • 1,515 Answers
Hi, if you can't find the pilot shut off, all wall heaters have a gas line that supplies gas to it, the main line at the unit. There should also be a gas flex line going to it. It will have a valve on it to shut gas down to the unit for the summer. This will solve your problem. You will have to look for it, as it may be hidden from site for looks and decoration. You will find it.
Sincerely,
Shastalaker7
Heating Contractor.
Please be kind when rating. Thank you, I know you will.
Posted on Jul 16, 2010
I have a full tank of propane - my pilot light is sparking but it will not light? Any ideas on what to check? Thank you, Korby
Korby, I think you meant, your ignitor is sparking and you're not getting gas to the pilot. Since you have a full tank of propane, I can rule out that the tank is empty. However, I believe the tank or at least the tank valve is playing a role in this.
Turn the tank valve completely OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (Slow Motion, slow) until the valve is fully open. Then light the pilot as you normally would. If the pilot lights, you solved the problem. If it didn't, either the pilot light is clogged and needs to be cleaned or the heater's hose/regulator assembly needs to be replaced.
Endless Summer Patio Heaters are made by Blue Rhino. So, if you need parts, that's where you can get them. Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 09, 2011 | Endless Summer 153100 Open Flame Patio...
The pilot seems to light but then when I turn the knob to ignite the main burner, the pilot goes out. Is there a technique to clean the igniting assembly?
let the pilot light burn for a few min and get hot after this try slowly moving the knob over to full burn. Sometimes it just need to heat up.
Feb 14, 2011 | Endless Summer 233000 Open Flame Patio...
I have an Endless Summer (Blue Rhino) patio heater with model number 153100 and the pilot flame is not strong enough to keep the thermal coupling open. What has to be done to fix that?
The pilot jet may be clogged. If there is a flame, it must be small and blue. A large flame that is orange or yellow tipped means that there is a partial blockage in the pilot assembly which needs to be cleared. The pilot flame must also touch the thermocouple in order to heat it correctly. Make sure that the pilot jet and thermocouple are positioned correctly. If you have an extremely small pilot flame, try repalcing the regulator and hose as the regulator may be failing.
Sep 02, 2010 | Endless Summer 153100 Open Flame Patio...
When I light the pilot light it will not remain on after 30 seconds when I turn the knob to go from pilot to low or full heat. Further more attempts to relight the pilot fail even though I follow the...
Typically, when a pilot won't stay lit, short of being out of gas, is a faulty thermocouple. They are fairly inexpensive and not too difficult to replace and should fix your problem. My only other suggestion, is to make sure the pilot flame is a strong blue color and is actually heating the thermocouple tip. If it's a lazy yellow flame, it may not generate enough heat to keep the pilot flame on. In this case, using a can of compressed air with attached straw (like you use to clean computer keyboards) is needed to blow out the dust or spiderweb that is clogging the pilot orifice in the pilot assembly, which is the place where the pilot flame burns. Hope this helps. Let me know if you need any more assistance. Douglas
Jun 11, 2010 | Endless Summer 2300 Open Flame Patio...
I go thru the process of lighting the pilot light following the directions exactly, but as soon as I let the pilot light switch pop out so that I can turn it to the left to light the heater the flame goes...
The system works off of a thermocouple that is heated by the pilot. The thermocouple creates millivolts that magnetize a head behind the control knob. When you push in the knob the magnetized head behind the knob holds the gas valve open. So obviously the head is not being magnetized. First make sure that the pilot is not plugged and the flame is large enough to heat the thermocouple. Also sometimes you may need to hold the knob for several minutes before the pilot will stay on. Also patio heaters have a safety feature that will cut the millivolt circuit if the heater falls over. It is possible that this safety device is tripped or defective causing the pilot to not stay lit. Also check for any loose wires on the millivolt system.
Dec 21, 2009 | Endless Summer UniFlame (GWU501E) Open...
Heat does not turn to high. I can turn the KNOB to high, but the heat does not increase. The heater used to turn red when it was on high, but does not now do that. How can I incread the heat output. Model:...
It sounds like you are not getting enough gas at the main burner. Possible causes, bad regulator, easy to replace and relatively inexpensive. You could also have a partial blockage in the main jet orifice, not letting enough gas through. You have to take the head apart to service the main jet orifice, do the pilot jet orifice while you are in there. If you are not comfortable doing that, hire someone.
Oct 12, 2009 | Endless Summer 233010 Natural Gas...
Patio Heater
The pilot light has to heat up the thermocouple. Is the thermocouple in the flame? If so, the them. could be bad. Replace
Jun 28, 2009 | Endless Summer 1501 Patio Heater
Empire Wall Heater(propane) won't stay lit
You have a crack in your heat exchanger and it is sucking in products of combustion. Replace the heater. OR there is a blockage in the intake or exhaust vent. GET IT FIXED OR REPLACED!
Dec 05, 2006 | Empire GWT-25 Wall Mounted Panel Heater
Williams 3003622 Ceramic Wall Mounted Panel Heater Logo
56 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
