Question about Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin
Spin cycle won't work. any suggestions? I was told to resplice some wires that attach to the timer. I'm not sure where the timer is.
  • eclop Apr 29, 2008
    washer goes half cycle and when I push cancel it shows f20 erro code restarts at beginning of wash cycle and wont spin dry
  • Gary Davd
    Gary Davd May 11, 2010
    is there water still in the unit??
My washer wouldn't spin dry, but it had the code F 21. Read this from another guy on here. Take the front off. Mine had a drain valve connected to the pump. Un screwed it and it was full of change, 2 rings, nuts & bolts, 2 keys and lint. Things that were in pockets got caught up in there were it wouldn't drain. Now my washer spins dry perfectly.
Posted on May 05, 2008
    Genius:
  • 1,028 Answers
Ckd fill hoses be sure hot and cold are full on ck screens at washer end of hoses in inlet valve are they clean?
Posted on May 04, 2008
Washer will not drain on the spin cycle
since the spin cycle is high speed, you may actually have a problem in the door lock safety switch
Oct 26, 2014 | Washing Machines
Whirlpool WTW4950XW Washer won't go past the sensing cycle.
It may be as simple as a defective door switch or even a clogged drain hose (the hose between the tub and drain pump. Here are some videos that may help you more than i can. This guy knows:
http://www.youtube.com/watch?v=Aq7a3j7pFUM&playnext=1&list=PL5258B1D98A50745F
Jan 12, 2013 | Whirlpool WTW4950XW Washer
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
Will not spin, clothes are soaking wet.
Are you sure washer is level? I solved our problem that simple and I had worked on solving it for weeks until I double checked the level and found it a little off. Now it works wonderfully.
May 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Roper RAL6245AW0 Washer Won't Drain or Spin
We have a Kelvinator Washing Machine that just won't drain , but fills , agitates , & spins just fine. What shall we do?
Oct 13, 2008 | Washing Machines
Washer not spin cycle or Drain
It maybe the timer has a fault in it. You should have a spin cycle on the other side try useing the drain and spin on that side. If that doesn't work replace the timer. Also if you are able to, undo the control panel should only be 3 screws on the back and make sure no wires have dropped off the timer panel. But please unplug it first
Jun 29, 2008 | Whirlpool LBR4132JQ Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
