Question about Coleman Hot Water On Demand
Have three coleman hws same problem on last weekend. Fully charged batteries 6.45volts. New gas bottles. Turn unit on water starts to run gas ignites for one to two seconds and then goes out water will continue to run if left on Three families left in the cold. Problem?
It will probably be one of two issues. Either the waterflow sensor is not working correctly or the propane valve connected to to control knob is stuck shut. The water flow sensor is located on the side of the copper element (grey box) check that it spins easily. The propane valve is attached to the control knob by a long metal wire and should turn freely as you turn the control knob to warm
Posted on Aug 31, 2010
Rinnai 32 Hot water system cutting out
The water flow switch is bad but may be able to be adjusted by yo if you closely examine it.
Jun 30, 2013 | Rinnai Heating & Cooling
Water pump and ignitor do not work
took coleman away for weekend wouldn't work. Very dissapointed, was cold would have loved a hot shower. Had charged battery, when I went to start it. It wouldn't go, light come up as battery low tried it on car charger still no luck. Got home and looked up this site told me to try taking filter off pump and putting a long nail inside to turn pump to make sure it wasn't seized. And guess what every thing works well thank god, water temp was dodgy as well but now all good. Thanks to people that do reply to these sites, it has saved me a lot of money and frustration.
May 23, 2011 | Coleman Hot Water On Demand
I am in ecuador and have had a local "plumber" install a lpg tankless water heater for me. After more difficulty than there should have been it's up on the wall with the water and gas lines attached but it...
The system is ignited by turning on a hot water faucet causing water to flow through the unit activating the igniter.You could disconnect the gas line at the unit turn the valve on and off real quick and smell for gas.If there is air in the line you may have to let it run or purge the line just long enough to make sure gas and not air is comming out.You might want to have utility company do this if you have any worries .I would make sure it is set up for lpg and not natural gas. And then and this is quite often the problem the gas line feeding the unit should be at least 3/4 inch pipe and fairly close to the main supply and in no instance the last fixture in system unless the pipe sizing is adequate for the amount of gas the unit needs to run.If sizing is the problem sometimes rather than running new pipes your utility company might be able to adjust the pressure comming out of the tank to make up for it. Hope this helps good luck
Jun 22, 2010 | Vacuums
Turn the ignition and the engine barely cranks
You could have a starter that draws too much amperage or a bad ground. Check your grounds at the battery cables and check that the battery is fully charged. You may have an alternator problem. If the battery is fully charged check the starting and charging systems and that will tell you your problem.
Mar 10, 2010 | 1996 Ford F150 Regular Cab
Coleman Spotlight PML8000 lasts only a few minutes when charged
your battery is gone. chk with coleman for replacement
Dec 13, 2009 | Cars & Trucks
Just put a new battery in last weekend. Now it
several factors could be this item, terminals and cables dirty, clean thoroughly with water and baking soda, rinse and let dry, Alternator not charging the battery (take it out and have it tested, if you have not done so) Faulty starter or solenoid, take out and have checked . I did all of the above and the next item was what i needed to fix my vehicle, faulty ignition switch (52.00 part) this takes about 2-3 hours to change out. Good luck!
Sep 13, 2009 | 1991 Honda Accord
Electric start will not work
You should remove the battery and charge it up outside the machine then take it to your local auto parts store where they will load test it for free. It must be fully charged to test. Most of the time those small batteries are dead due to the heat produced in the machine. These batteries only run about $30 or less usually.
Note: BEFORE CHARGING if the battery is not sealed ensure the battery water level is good (no exposed plates, usually the water is about 1 1/2" below the top of the holes). Use pure bottled water if you need to add water.
Mar 27, 2009 | Honda 6370C - Parallel Power Kit For ...
85 Pathfinder enigne died, while in traffic
if it will crank but not start check the ignition components and fuel pressure if it wont even crank check fuses and all starting system electrical connections and components
Oct 18, 2008 | 1995 Nissan Pathfinder
Coleman Hot Water On Demand Logo
1,661 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
Vernon Taylor
David Payne
David Payne
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
