Question about Kenmore Dishwashers
My kenmore ultra wash 111 doesn't seem to be getting water pumped into main unit i have checked the connection to plumbing and that is ok any ideas were to look now
    Genius:
  • 1,075 Answers
I would say its not getting water pluming needs checked.adrian,,,
Posted on Jul 15, 2010
Kenmore washer needs two spin cycles
Have you checked the timer? Sometimes the little motor inside of it gets stuck or the concacts become burnt.
Good luck,
Marty
Jun 21, 2014 | Kenmore Washing Machines
Dishes not washed properly. Have tried universal plus at 65deg, the water does not seem to get hot until it is in the main wash cycle. Used to use the universal cycle at 55deg with no problems. Also the...
Hi
Thanks for using FixYa. Check the water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible.
This would have happened as the dishwasher was overloaded with more than prescribed number of dishes. Check the spray arm and pump cover for splits or leaks. As the dishwasher is not draining properly, this issue is related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 07, 2010 | Miele 24 in. G656SCi Plus SS Built-in...
I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My kenmore ultra wash plus is not draining
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore ultra wash dishwasher model 15752000 is not draining completely after cycle has finished
Hi
Thanks
Rylee
Oct 21, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Jun 29, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Model 238322100 ser cm4768086 type 111
Check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 22, 2009 | Kenmore Washing Machines
Water comes out the bottom of washer as fast as it goes in the top
hazy, it's possible it's running out your pump. You need to pull the cabinet off to get a real look at where the leak is coming from. Check out the pics...and post back.
Apr 23, 2007 | Kenmore Elite 20972
Dishwashers Logo
95 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
