Question about LG LP1200DXR Portable Air Conditioner
When running unit the water is coming out of the front of the unit. tred to drain but no water in the drain tank. but we can hear the water moving around inside the ac
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
Were do i get the manuel for model number ph3 12r03 is the model number were or how do I drain the water and can you send me a manual
Here is the link to the manual:
http://s3.amazonaws.com/szmanuals/b0348062b23e23cd40550b61e1dc5f43
Here are those particular instructions:
Compressor Indicator
The " " icon will light up on the control panel display when the compressor turns on. The " " icon will turn off when the compressor shuts off.
Emergency Condensate Holding Tank
When the room temperature is low and the indoor humidity is high, the air conditioner may not be able to evaporate some of the moisture fast enough. When this happens, the water will accumulate in an emergency condensate tank inside the unit. Once the emergency condensate tank is full, the unit will automatically shut off and the " " will appear on the control panel display. To empty the condensate tank, unscrew the screw plug at the bottom back of the unit. You will need a small pan, approximately 1" high to catch the water coming out of the condensate tank. Once the condensate tank is drained, the unit will begin working within a few minutes. The emergency condensate tank holds approximate
ly 1.5 Liters of water.
Another option is to purchase a small hose from a hardware store that can fit around the 5/8" drain plug on the back of the unit and drain the unit into a gravity drain or larger pan for continuous drainage.
To resume operation quickly, empty the water container according to the following steps:
1. Turn the unit off. Do not move the unit when the water container is full.
2. Place the drain pan accessory under the drainage port at the back of the unit.
3. Remove the screw plug from the drain hole. The condensate water will drain out automatically. When the drain pan is full, screw the screw plug back onto the drainage hole to stop the water flow. Empty the drain pan. Repeat until all the water is emptied.
Once the water container has been emptied, screw the plug back onto the drain hole. Do not allow the
water to drip continuously into the drain pan, as it might easily overflow.
Jul 13, 2014 | Soleus KY-34 Portable Air Conditioner
Unit will not run after about an hour until tank is drained -if a container is placed under the unit with plug out the unit will run like. An awful lot of water seems to come out of the unit.
Thing to remember about an Air Conditioner is it is transferring heat, so if you are in a hot humid enviroment you are going to condense more water, which will fill the tank up quicker.
If the tank has a spot to connect a hose to the tank, and you have a drain nearby, might be worth hooking a hose up.
a thought anyways on a fix
But the water is normal
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 21, 2013 | DeLonghi CF210 Portable Air Conditioner
The full tank light on the front comes on even after being drained.
is it a float switch stuck? Usually the pan has a switch or sensor to tell the unit when it's full. Sensor may need cleaning/drying or, as I say, may be a stuck switch.
Aug 07, 2012 | Danby DPAC7099 Air Conditioner
Once the 'condensate tank' is drained the unit will NOT reset....The tank full light stays in and the Unit continues to run the fan, but will not heat ...for HOURS........Help.....I realy did
When our unit was moved with a full condensate pan, the switch lever became lodged in the "full" position and the unit wouldn't heat. This is how I fixed it.
1. Unpug the unit.
2. Remove 8 screws from the housing.
3. Remove the rear housing, swinging the bottom away from the chassis.
4. Remove the front housing similarly, taking care to release the tabs from the vertical chassis rail, and avoid stressing the wire leads to the control panel.
5. The condernsate float and switch are at the right front at the base of the chassis. Assure that the float is free from obstruction and debris in the condensate pan. Assure that the switdh lever is free to travel to the limits.
6. Re-assemble the unit it reverse order.
Apr 21, 2012 | Soleus Heating & Cooling
Water leaking out of frigidaire portable air conditioner at left back bottom corner? Model FAPO94P172 or FAP094P172??
First, have you drained the tank recently. If not, the warning light or auto shutoff failed and the tank may be overflowing. Worse case scenario is the that the tank is dirty and is not allowing the coils to cool and the dripping water you see is from the cooling coils. Since the tank is not removable, it's very difficult, at best to clean the tank.
If you drain the tank and before reinserting the drain plug, try to get about 1/2 teaspoon of bleach in the drain hole. followed by 2 cups of water. Of course you'll have to use a funnel of sort to do this. Reinstall the drain plug and move the unit around so the water and bleach will slosh around. Then run the unit until the bucket is near full again and drain it thoroughly. Look at the color of water draining out, for an indication that there is dirty water. That will be a good indication, that some cleaning of the tank has taken place.
Hope this helped you and thanks for choosing FixYa.
Jul 29, 2011 | Frigidaire FAP094P1Z Portable Air...
Suds or blocked pump is a message popping up. the door to the front washer won't open as it says the water level is to high.
let it rest a while so suds can disappear then unplug the unit for 1 min then plug back in it should drain by its self if not do not select wash cyc but a spin/drain then you should hear the pump running if you don't hear the pump running you can get a wet/dry vac stick on the drain hose and empty the washer that way if water not come out you have to axcess the pump and pinch off the drain hose from the tub and remove the object from the pump be careful that you don't have a mess with water leaking from the tub good luck
Aug 27, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Hear a gurgaling noise from the lower front passenger area when I first start moving forward
Could be several things, coolant in the heater core or water moving around in the evaporator case. Is the coolant level full and does water come out the drain tube of the evaporator on the ground when the A/C is running. Those are two things I'd check first.
May 23, 2009 | 2004 Jeep Grand Cherokee
WATER LEAKING FROM UNDER THE WASHING MACHINE
follow the hose from where it connects into the washer.. take off that panel and pinpoint leak. more than likely a hose is unattached
Apr 15, 2009 | GE WWSE5200B Top Load Washer
Washer won't drain
Yes Get a space heater and run it by the frozen pipe. Turn off all electricity to avoid shock and it should break free by the morning. Run it at a drip from now on during really cold night just like the sink but set washer on DRAIN this will help. Good LUCK
Dec 07, 2008 | Kenmore 44042 Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
LG LP1200DXR Portable Air Conditioner Logo
196 people viewed this question
Top LG Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
