Question about GE APN10AA Portable Air Conditioner
No water is draining into the bucket, seems just like outside air is coming in
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
How to remove airlock from hot water system
At the boiler should be a purge setup. This consists of a valve to shut the zone off, and downstream of that valve is a drain ****. Attach a hose to the drain ****, and with the boiler running, close the valve and open the drain ****. (Turn the heat up on one zone at a time if you have multiple zones.) You should be able to notice when the air comes out of the hose by hearing it and the hose twitches and jumps when large amounts of air come out. After the air stops coming out, open the valve , close the drain, flip the bypass closed, and let the water circulate, then reapeat procedure. Do this until you hear or see no more air. You can run a long hose outside or you can use a bucket and a short hose. Using the bucket allows you to actually see the bubbles of air, but you will be dumping many buckets before you are done. Most boiler feed valves have a fast fill lever that bypasses the slow 12 psi that the boiler is normally fed at. Using this will speed up the purge considerably, but don't forget to flip the lever back down between, and after purging or the boiler relief valve will blow off and make a mess. Good luck!
Mar 18, 2017 | Water Water Heaters
Hi, I have a Haier HD306 Dehumidifier. I'm having an issue of the water dripping onto the floor. There is no crack or leak coming from the bucket itself. The leak seems to be coming from the back...
When my unit did that, I found that it was because the drain tube was plugged with lint and/or dirt...
Run a large tooth pick or wire up inside the drain and see if the water doesn't start running right out of there...
heatman101
Jul 26, 2011 | Haier HD306 Dehumidifier
I have a comfort air dehumidifier that does seem too effective. also theer is a tube on top of the water bucket? whats that for?
That's the water collection tube, that drains water into the bucket. What's the other other problem that makes it seem, that the dehumidifier is not to effective?
Jun 01, 2011 | Comfort-Aire BHD-301 Dehumidifier
Buckets of water leaking but the reservoir is dry!!!!
If you have cleaned the air filters then that is the first step. Next you want to check the condenser coil. That is the coil that is outside. If it is dirty you will have a low charge situation which could cause lots of condensation. Also if the condenser coil on the outside is clean and you are getting lots of water than you my have low charge of refridgerant. If that is the case you will need a professional to come and charge the unit and find the leak. Did you check to see that the unit is level. Because is should drain to the outside. The unit should be installed in a way that the water drains to the outside.
Aug 23, 2009 | DeLonghi CF210 Portable Air Conditioner
P1 error too often
you have high humidity. Its supposed to drain the water into a bucket. Sounds like south florida to me?
Nothings wrong with it except you have a high humidty problem. Wet basement? Good luck
Aug 17, 2009 | Danby DPAC8020 Air Conditioner
Drain hose in floor drain but fills up water bucket
wow, that's a weird one there. just to check, you did turn thr drain connection all the way down and remove the cap? nothing inside the drain connector? the hose is not too small or run too far? is the water coming out of the hose and in to the bucket at the same time if it is I would think ther is an internal leak somewhere and take it back for an exchange if new. good luck let me know if this wasn't any help for ya
seth
Jun 12, 2009 | GE APH10AA Air Conditioner
A/C Clogged drain pipe
Can you get to the hose in the house unit? If so canned air
May 26, 2009 | Carrier Heating & Cooling
Water going into carpet instead of ac water bucket
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
May 07, 2009 | Heating & Cooling
APE08AK GE Portable Room Air Conditioner isn't draining
I had the same problem and unscrewed and removed the back cover (AFTER I UNPLUGED THE UNIT) and noticed there is a small black tube that the drain tube connects to. Mine was broken off track and I had to physically remove the small black tube, put it back in it's place and super glued new tabs along the side so it would tilk back and drain the water in the bucket vs. the floor via the unit.
Hope this helps.
May 25, 2008 | GE APH10AA Air Conditioner
GE APN10AA Portable Air Conditioner Logo
135 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
