Question about Friedrich QuietMaster KM18L30 Wall/Window Air Conditioner
How do you mount a friedrich km14j10 . can't screw the brackets into the brick wall outside. just makes holes in the brick and screw and brackets do not stay
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
Westinghouse dryer LD505E is to be mounted on a brick wall ,what size rawlplugs & screws are needed .I bought the wall bracket mounting kit
that unit does not have wall mounting information its user manual
or a wall mount bracket supplied with that dryer
its a 5KG dryer by the looks of it
thats means its load a with 5kgs of wet clothes on the floor
suggest to me its no meant to be wall mounted
http://laundry.manualsonline.com/manuals/mfg/whitewestinghouse/whitewestinghouse_dryer.html?p=7
wall mount kit might be say suit most dryers
you have to go by common sense
use bigger mountings and fixings that you think it needs
has to hold up on the wall
this much weight
the all up wet weight of clothes
the dryer dry weight empty
and steady any vibration with the rotation on full load
into wood walls depends on the thickness of wood
if into dry wall ...need to hit the wall studs centre
I would not try it
if going into brick concrete ...hammer drill in and . ranset bolts
Sep 16, 2016 | Dryers
How to install wall bracket for Hitachi tv
make sure its on a brick wal mark were you want it drill holes and plug with good plugs and screw to wall with some good long screws use extra screws if needed.
if its a partition or stud wall again use some good strong plugs and the right screw fixings
Aug 11, 2015 | Hitachi Televison & Video
Rehow could fix the sreen on wall?
Remove the LCD monitor stand, purchase a wall mounting bracket. There are several types, one is on an articulated arm which allows you to left, right, up and down. Another type mounts flat to the wall with limited up and down adjustment.
You need to check the mounting holes on the wall brackets so it matches the mounting screw holes on the LCD screen.
Nov 26, 2010 | LG 22" FLATRON LCD Monitor
Moen 3836...lost installation manual...what size drill bit for the hand held brkt.
There is no single answer that I can give you because it will vary due to material you are mounting to. If you are going to be mounting on ceramic tile or fiberglass shower wall I would recommend you use the plastic anchors that come with the bracket and mounting screws. Use drill size 3/16 drill holes and insert anchors. Mount bracket and screw in place. If you have hollow wall with nothing but sheetrock to hold the bracket I would get small butterfly anchors from hardware store and drill hole slightly larger than the wings on fastener when they are folded back along side the screws.If you have a wood backer board behind shower wall then drill holes with 1/8 inch bit and use screws long enough to reach through shower wall and sheet rock and mount bracket. Hope this helps you. Thanks P.S. If you have to drill thru ceramic tile you will need a carbide tipped bit.
Nov 26, 2010 | Moen Plumbing
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Hoover 5010D dryer
There should be two rectangular holes about 2mm wide and 10-12mm long. There is a wall mount bracket [D470] which you install against the wall and then the hardest part is getting the dryer on the bracket.
Obviously when installing the bracket make sure that the wall and the screws can hold at least 30kgs.
Jul 18, 2009 | Hoover Dryers
The towel bar just fell apart. The wall mounts remain in tact as well as the mounting hardware on 1 side (the piece that the bars (this towel rack has 2 bars) slide into. I can't figure out what holds...
The part that holds the bar up should either have a screw in the bottom to tighten up against the wall bracket or a hole to access a scew and turn the screw out to tighten to the wall bracket
Jun 20, 2009 | Gatco & Channel& Satin Nickel Towel Bar
Sounds easy...but
Installing one of these between two cabinets and supported by the one above it is a pain ..but even worse if you don't have the installation directions. If you are relatively handy and have some carpenntry experience, I'll walk you thru the way I install them. First off, I assume you are installing this above a stove and betwwen two wall cabinets.. You need to do a little preparation work first. locate the wall mount bracket and you should have a packet of hardware ( primarily two long screws that will be used to support the front of the micro from the cabinet above) If you have all this.. you'll need to determine if you are going to vent the micro back into the room or plan to vent it outside. The simplest is to vent it back into the rook thru a charcoal filter but if you are going tovent it outside, you have two choices.. one is to vent it up thru the cabinet and outside via ductwork that you buy..if the microwave oven is being attached to an outside wall then it is easiest to vent it straight out the back ( i say this because you have to orient the blower in teh configuration that you are planning to use) Let's assume you will be venting this back into the room ( that's the easiest ) and move on.. The wall mount bracket supports the back bottom of the microwave oven when you secure it and the two long screws will be used to bring the front of the micro up against the bottom of the cabinet above it... I normally locate the wall studs and then buy and fit a 1/2 inch piece of plywood onto the wall where the micro will be mounted. The microwave will project out 1/2 inch further as a result of this plywood panel but.. you can use lots of drwall screws to the secure the plywood to the wall studs and then you can mount the wall bracket onto this plywood without having to worry about where the studs are and if it will support the microwaves weight. Mount the bracket onto this plywood piece. I will use drwall screws and add flat washers to them to provide additional support. Once that bracket is installed, you will need to figure out how you are going to provide power to the microwave. If you are replacing an existing oven then you will probably have a power fees inside the cabinet =situated above the microwave oven. If not, then you will need to provide a power feed for this. In the old days, most of these appliances were hard wired into junction boxes but nowadays, most appliances are treated as removable and all you will need is an outlet box in the cabinet above. I suggest you bore a hole large enough for the power cord plug to fit thru the bottom of the cabinet so that you can plug it in. The next part is the hardest to accomplish.. If you look at the top of the microwave oven, you should see two holes near thhe front and on top. Those two holes have floating captive nuts inside them that the long screws ( included in your hardware kit) will be used to snug the front of the micro up against the bottom of the cabinet above it.. The trick is to measure from the back wall out to where these holes need to be drilled in the cabinet above so that they line up. You can drill bigger holes than you need and use oversize washers if necessary. If this sounds complicated ..it IS.. i have put many of these in and unless you are actually doing one, youhave no idea how involved this can be.. even worse with ducting to the outside.... I hope this gives you some tricks on how to install.. And um.. if you do get this all together, you will need some help actually putting it in place.. You'll need to catch the back of the microwave onto the tabs of the wall bracket and then feed the wire thru the cabinet while you lift the entire thing up to start the screws from the cabinet down onto the top of the microwave. I'm a big guy and have done these myself but it is not easy.. Hope this helps you.. Lastly, here is a link to the GE website where you can download the user manual and search their FAQ for install details ( in retrospect, I just should have given you that info).. http://www.geappliances.com/service_and_support/literature/
Hope this helps you...
Sep 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How to Install Towel Ring
Place the mounting bracket against the wall and trace around the inside of the two ovals on the bracket. Gently drill a hole into the center of the traced oval. If you hit a stud, you will not need the anchor. Carefully tap the drywall anchors into the holes. Screw the bracket onto the wall, using the screws provided, into the two anchor points. Make sure the set screw is backed out far enough to set the escutcheon over the mounting bracket. Place the escutcheon over the mounting bracket, top first. Tighten the set screw with the Allen Wrench provided.
Aug 27, 2008 | Kohler Bathroom Accessory Set with Classic...
Friedrich QuietMaster KM18L30 Wall/Window Air Conditioner Logo
106 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
