Question about Kodak EasyShare One Digital Camera
How long does it take the battery to charge?
I've been charging the camera for 2 days. How long does it take the battery to charge?
  • 72 Answers
Should not take more than 12 hours certainly. If you bought this camera new, get a replacement. Otherwise if the battery does not hold charge or empties rapidly, you should get a new battery type KLIC-5000 from Kodak.
Posted on Jul 15, 2010
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
My finepix s3400 will not turn on. I've tried almost everything and I'm really annoyed. Is there something i can do to fix it?
Mine wont turn on either, the battery is fully charged and inserted properly. I can tell this as the pre-flash light comes on but nothing else, the only way to get the pre-flash light off again is to remove the battery.
Mar 08, 2012 | Fuji FinePix 3800 Digital Camera
Very low battery life
I have the same camera. It sounds to me that there is a fault with the camera itself and not the battery. You might be better sending Canon an email and asking them. My battery lasts forever so I would think if you already purchased another battery you've eliminated that problem. It might be the contacts inside the camera that are not accepting the full charge. Does the camera battery on screen show that it's full after you've charged it? Maybe trying charging it overnight and then trying it out the next day.
Dec 27, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
NEEDING TO CHARGE BATTERY. WHEN WE PLUGGED IT IN, THE LIGHT DID NOT COME ON. WE HAD IT PLUGGED IN ALL DAY LONG AND ONLY A QUARTER OF IT WAS CHARGED. FIRST OF ALL WE THOUGHT THE LIGHT WOULD COME ON TO...
Hi, Sounds like the battery is quite old which means its probably stopped being able to hold a charge which would cause the problems you've described. The solution would be to buy a new battery.
Jun 13, 2011 | Canon EOS Rebel XS 35mm SLR Camera
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
I try to turn on my camera and the lens comes out but then goes right back in and beeps as if the batteries are low but I know they aren't. I can still view the pictures I have already taken by pressing...
hi
i know its sounds odd but yes the charge on the batteries (Voltage/Amps) is falling short for the camera to start as it takes more power to run the camera than to just preview your pictures
one suggestion i can give here is
(this could be potentially hezardous so tread caution)
if you have rechargale batts then try electro jump to them take any source which is roughly 2-3times the voltage of the batteries (eg: if the batt voltage is 1.25 volts take a 3-5volts source) and connect the +ve wire to the +ve and -ve wire to the -ve of the battery and hold for 10 to 15 secs and then immediatly place it for charging and let them fill charge and use them till the batteries are completely drained
repeat this cycle for 2 -3 times and batteries will come back to life
be careful to connect the wires correctly else they might destroy the batts also not to hold for more than 10-15 secs
cheers
pls rate if this was any help
Jul 06, 2009 | Samsung SL310W Digital Camera
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
I am trying to charge the battery. The charger is flashing a red light and the battery won't seem to charge. Placed it in the camera just in case, and it won't turn on.
Well, with my Nikon, the light flashes to show the battery is charging. It stays on when it's charged. My battery and spare battery are 2 years old and working fine. I'd say wait till it stops flashing...hour or 2 in my case, though I never let them run down all the way.
Jun 28, 2009 | Cameras
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Kodak EasyShare One Digital Camera Logo
129 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
