Aiwa cassette deck won't eject
Aiwa AD S40 cassette deck: Eject door jammed. Button won't work. Best way open the case to fix?
  • 1 more comment
  • ann flum May 16, 2008
    both cassette seem to be jammed wont open wont play
    cassette not working
  • rdrunnner Jul 27, 2008
    tape 1 on a CX-NA50 AIWA shelf system will not eject or open in order to remove the tape.
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Posted on Apr 20, 2009
Aiwa AD F660 cassette deck. Having changed the drive belts, the eject button does not now work. Hook holding the cassette door shut does not drop enough to release. How can I fix this? Thanks, Brian
Have you trapped wire or something near the hook mechanism stopping it from getting full travel when the button's pressed?
The nice people at HiFiengine have a service manual for the deck, free you just need to join.
HTH
Aiwa AD F660 Manual 3 Head Stereo Cassette Deck HiFi Engine
Jan 19, 2018 | Aiwa Audio Players & Recorders
Tape an catridge stuck
Unfortunately, the best chance you got of getting the tape out is to open up the video to release the tape.
Feb 08, 2008 | Aiwa HV-MX1 VHS VCR
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
I just got an Onkyo R1 TA-RW505 dual cassette deck and the left deck door won't open with the eject button. I did get it open by sliding a slim knife behind the door and it appears that there is a
This is most common as the catch is there to stop you from opening the cassette door while the head base is in the up position. The reason many of these cheap dual cassette decks all have this problem is that the mechanisms are not built to last and then the cost to repair them exceeds their value. You need to find out why the mechanism is not getting back to the stop position and when you do this the eject issue will be fixed. Typically it is a stretched belt.
Putting it in is another matter though.
Mar 11, 2013 | Audio Players & Recorders
Aiwa cdc-x317 will not eject cd. How to eject cd from Aiwa cdc-x317?
Somewhere on the front of deck there should be a small pinhole just big enough to fit the tip of a pen push it in either pen or Sharp object. It should force it out.
Sep 11, 2011 | Aiwa CDC-X317 CD Player
Cannot get cassette doors to eject
the motor that drives the mechanism is jammed or burnt out.if you remove the cover and turn the big metal weights driven by the motor,the unit will dock the assembly and the door should open.
it thinks it is playing a tape and that is why the eject doesnt work
May 26, 2009 | Sony Audio Players & Recorders
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
Cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Nov 02, 2005 | Aiwa NSX-A115 Shelf System
1,094 people viewed this question
 Grubhead
Grubhead
