Question about Whirlpool 24 in. DP940PWP Free-standing Dishwasher
My dishwasher is draining properly.
My dishwasher isn’t draining the water properly. Assuming my problem isn’t a kinked hose, is there a cleaner that can be put in the dishwasher to unclog the dishwasher/hoses?
    Genius:
  • 1,075 Answers
Yes there is cleaners.Check filters at bottom of machine fiirst,then buy an cleaner.adrian,,,,
Posted on Jul 15, 2010
DOES NOT DRAIN ALL THE WATER OUT OF THE INSIDE. DISHES ARE STILL NOT DRY
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | LG 24" XL Tall Tub Built-In Dishwasher -...
I have a small dishwasher it goes through all cycles water won't drain out of the bottom
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
Not draining complety
Hi
Thanks
Rylee
Sep 07, 2010 | Admiral 18 in. DWCA500AA Free-standing...
Water does not empty from dishwasher
Hi
Thanks
Rylee
Jul 04, 2010 | Maytag MDB9750AWS Built-in Dishwasher
The dishwasher does not completely drain.
Hi
Thanks
Rylee
Jun 10, 2010 | Whirlpool 24 in. DP940PWP Free-standing...
Water won't drain
Hi
Thanks
Rylee
Jun 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water will not drain
Hi
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 22, 2009 | Electrolux Frigidaire Professional Series...
Dishwasher doesn't drain when i run the dishwasher it doesn't drain the water out.
Hi
Thanks
Rylee
Nov 11, 2009 | Dishwashers
Hi
Thanks
Rylee
Nov 03, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Will not drain water out of tub
Hi
Thanks
Rylee
Oct 26, 2009 | Kenmore Dishwashers
Whirlpool 24 in. DP940PWP Free-standing Dishwasher Logo
281 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
